Old 02-26-2007, 09:46 AM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Default LS-7/Speartech/Racepak Question
C'mon man I need some help here....and you are married!!!
Ok, so I have gone over to the other side as far as LS motors and am currently shopping for an LS-7. I also wanted to run the Racepak dash with a Speartech harness. For ease of install and the fact that I really like the Racepak set up for its simplicity(relatively speaking of course).John(at Speartech) and I have gone back and forth a time or two and he has a question concerning sending units, data acquisition and the Racepak unit:
from his email:
I would have to know more about the sending units(LS2 & 7) though, as none of these engines use direct gauge sending units from the factory. All of the late model LS2 and LS7 engines take PCM data and send it to the factory gauge cluster thru a serial data line. Are you saying that's how this unit operates?
Here is where I need help-
1. Can I get a heads up on the factory sending units and their operation (or function) and how is this info transmitted to the ECM.(I hope I am asking the right question)
2. Does the Racepak set up recieve its info from a serial data line AND is their a diagram or schematic for the Racepak set up as far as plugs and ports on the rear of the unit. John bascially stated that if he can get the data on the plugs (There are 4 stations on the back of the Racepak) he could incorporate it into the Speartech unit that is a plug and play for the LS-7.
If their is indeed a better way-tell it. The MEFI4 unit has the data to start and run the LS-7, but how about if you run headers and a "Hot Cam". Is that a limitation of the MEFI4 unit vs the Speartech ECM? IE adjustability via programming through soft ware.
I hope I am not coming across as a dummy here, but I am definately more of an old schooler Fortran/Cobal thinker trying to change his ways to this new fangled modern tekknologie. If their is a better way- Please tell me and be as gentle as possible as I have a delicate constitution. I am not calling for a pissing match this vs. that mind you, just strait info based on experience and installation.
Jim
Old 06-12-2007, 10:58 AM
4mm 4mm is offline
Bump, this is a good question, can anybody help out?
Old 06-12-2007, 11:59 AM
camcojb camcojb is offline
The racepack is "plug and pray" according to Stielow. Kind of tough to get programmed from a logic standpoint, but works well once completed. The MEFI4 has the tuneability for the cam. Mark has the MEFI4 and Racepack joined so I know it can be done.
Old 06-12-2007, 02:11 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Mark told me that the Racepak and the MEFI 4 communicate, so it's not as simple as hooking wires to it.
My LS7 69 Camaro
Old 07-14-2008, 06:30 AM
Anything new Ummgawa ? I saw at Stuarts cars is set for racepak ( at DSEs site )
63 Z06
Old 07-14-2008, 07:04 AM
James OLC's Avatar
"supposedly" MSD has made the system more plug and play with their new dash when using the MEFI4 harness. Unfortunately, they don't have a street version available yet, and the tech that I have received from MSD is inconsistent enough to be worrysome.
I guess I'll let you know soon what happens when we try it.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 07-14-2008, 07:57 AM
Lateral-g Moderator
Running the new IQ3 Racepak with an LS7 and everything works well except the tach. Still working the bugs out of that, but racepack has an easy solution that DSE is doing now.
Love the IQ3 dash though.
I'll let U know as soon as its fixed.
Old 07-14-2008, 11:56 AM
Thanks Stuart!!! Since you are "insider" to DSE can you ask if they can offer it as an plug and pra..play package
63 Z06
Old 07-14-2008, 04:55 PM
Lateral-g Moderator
I'll get the scoop.
Old 07-15-2008, 02:31 PM
Lateral-g Moderator
Part from MSD ordered. Distributorless ignition driver. Once its in and running I'll follow up.
