Old 05-07-2007, 12:23 PM
Thank you Clill for really good info!! Bad news are i need to think something my self with it
63 Z06
Old 05-07-2007, 05:15 PM
tyoneal's Avatar
tyoneal tyoneal is offline
Originally Posted by clill
The Mule has a Lokar and I had put one in a 32 Ford I had. My real world opinion is the Lokar does not have enough leverage. They are too hard to pull...aka the handle is too short. In a panic situation I think it would be lacking. I have driven cars with factory hand pull levers that worked much better. I just replaced the assembly in the Mule because of broken parts in it. Now the button on the new one popped off and I am taking it apart again. The Lokar would not be my first choice. If you can find a factory lever that would work it would probably be a better piece.
Thanks for the insight.
I would definitely want the mechanism to be dependable AND easy to use. Anything short of this would be dumb IMHO.
This was very helpful.
Keep us posted on what you finally use.
Has anyone used the Corvette Hand Brake?
Old 05-07-2007, 06:10 PM
awr68's Avatar
awr68 awr68 is offline
I still have a hand brake from a 4th gen camaro I might take a look at...thanks Charley for the feed back! However I'm sure the Lokar will work for as little as I will drive this car...it can't be a DD with my job. Perhaps I should fill the hole I cut in the floor and go with a foot brake....
Tony
'68 Camaro
Old 05-09-2007, 05:42 PM
Perry Mitchell Perry Mitchell is offline
In my opinion, unless you are going to thrash you car or use it to drift with, the Lokar unit will work just fine. I mounted mine above the floor tunnel and ran the cables under the console ( which runs all the way to the back of the seats) and exits near the rear wheels. This really cleaned up the under carriage for that show car look.
