Old 07-08-2012, 06:20 AM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by GRob View Post
Mark,
Fantastic build, and the components are the best of the best.
I'm surprised you don't have a bigger interest in an IRS setup for the rear, I think it'd be helpful particularly on bumpier corners, allowing you to get the power down sooner and keeping the car on line better.
Also, have you ever thought of a traction control system of some sort to also help you get the power down earlier?
For me the solid rear axle works great and has been very reliable and lighter than an IRS. We have learned a lot about IRSs over the last 8 years and they are better if you have the time and money to tune one.
I have driven a few traction control systems and (PTM) performance traction management systems and so far I've been faster without them. I can say that many less experienced people are faster with them. If you know the track, torque curve of the engine, gearing and have a very good tire model the PTM system is faster. But that means you need to tune it for each track and tire. I have been drivening big power cars with street rubber on them for many years and I’ve been able to calibrate my foot to get a good launch. But for 0-60 AWD is the way to go. Last year at OUSCI I had a near perfect launch for the Speed Stop deal hold about 0.8 G acceleration until 80 MPH on that dusty pad but the GTR still beat me with just WOTing it. I’m traction limited for now so adding any more power is not going to help me for the Speed Stop deal. And my braking is also nearly maxed out with the tires we can use for OUSCI.
Stielow needs to get out in the sun more...And the dope helping him is confused because it isn't electric.
In MI it is either snowing or above 90 degrees so I stay in the shop….
My buddy Ryan Kuhlenbeck is in town to help me get the wiring done on the ’67. He has helped me on the last 3 cars so we have the wiring for the LS9s sorted out. It is also much easier now that GM has a GMPP LSA harness to start from.
We have another version of the LS9 blower inlet that is opened up more than the one on the Red Devil. We hope to see some power gains out of that also.
Old 07-08-2012, 06:26 AM
Roberts68 Roberts68 is offline
Do you run the stock Tremec shifter we see there Mark or is that just for mockup?
Old 07-11-2012, 04:21 AM
69Pressurized's Avatar
69Pressurized 69Pressurized is offline
Hey Mark, what clutch and brake pedal set-up are you using in this build? I know you've switched it up before in other cars. Thanks
Old 07-11-2012, 08:08 AM
Stielow's Avatar
I'm using the Tremec shifter. I'm using the stock '67 pedel set up with a 2002 F-car cluth slave with a DSE adapter bracket.
Mark
Old 07-11-2012, 08:13 AM
Rick D's Avatar
Rick D Rick D is offline
So how much longer?? Summers going to end!! Mark do you have to qualify for Optima or do you get in because of past winning?? If so where do you plan to qualify?
Rick
Old 07-11-2012, 05:42 PM
brownz brownz is offline
Mark
what clutch master cylinder do run in your cars?
Old 07-12-2012, 02:23 PM
Stielow's Avatar
The Optima guys already invited me. This car will be in the Optima battery booth at SEMA and in the OUSCI event. Now all I have to do is finish it....
Mark
Old 07-12-2012, 02:28 PM
Stielow's Avatar
Default Wiring Update
We are finishing up the wiring... Big job on a complicated build.
We keep a Excel spread sheet on all the wire, connectors and pinouts.
We will loom it all up when it is done.
Mark
Old 07-12-2012, 03:39 PM
Ketzer's Avatar
Ketzer Ketzer is offline
Looking at all that wire makes my head smoke and my right eye get all twitchy...
A whole nother level of incredible engineering! Just amazing.
Jeff-
Old 07-12-2012, 06:48 PM
Rick D's Avatar
What you can't just order up a new harness??
Rick
