Old 03-26-2015, 12:15 PM
samckitt's Avatar
samckitt samckitt is offline
Is there a preferred position where the AC pressure switch needs to mount? Between compressor & evaporator, evaporator - condenser, or condenser - compressor?
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-26-2015, 10:40 PM
Vince@Meanstreets's Avatar
anywhere between the condenser and evaporator. #6 line
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 03-27-2015, 11:37 AM
65C6Corvette 65C6Corvette is offline
Thanks,
This is helpful. Where did you install the trinary switch? Assuming that you also used it for the vintage air.
Old 03-27-2015, 11:56 AM
parsonsj parsonsj is offline
You don't want to use a trinary switch when the fan is being controlled by the ECM. You should use a binary switch to protect the compressor from over/under charge since the ECM doesn't control that.
John Parsons
Old 03-27-2015, 12:01 PM
Originally Posted by 65C6Corvette View Post
Thanks,
I usually put it right into the drier. But if I can't inline on the high side hidden in the fender.
Yes, there should be an AC input wire right? Let me see if I can find the pin #
Dealer for
NEVER FORGET -11
Old 03-27-2015, 12:09 PM
On the E67, the A/C request signal is via CAN request from the BCM, not a signal wire.
John Parsons
Old 03-27-2015, 12:38 PM
ECM fan request pins are a grounding circuit right?
Dealer for
NEVER FORGET -11
Old 03-27-2015, 01:10 PM
dontlifttoshift's Avatar
Originally Posted by mikels View Post
Shroud is 609 mm wide x 585 mm tall ( 24x23 inches)
Fan itself is not much smaller.....
To anyone that has an SRX fan, can you measure the blade itself for me? Using the eyecrometer it looks like the fan itself is 20" or more but I would like to have an actual measurement.
Thanks!
Donny
Old 03-28-2015, 11:11 AM
samckitt's Avatar
Has anyone found a decent price for the SRX fan? What prices are you finding?
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-28-2015, 11:34 AM
Yes, in a non-PWM setup, the fans are requested by a ground circuit.
John Parsons
