Old 02-15-2013, 10:07 AM
I just noticed something... that's my car on the lift in the photo... @ JRS...Good choice on suspension Guru...
Old 02-15-2013, 11:07 AM
carbuff's Avatar
carbuff carbuff is offline
If you switch to a TruTrac, can you still use that pump? It looks like it sits right where the differential would go, but I'm not an expert on diffs for sure...
Also, are you pumping out to a cooler? Where are you going to mount it if so?
Old 02-15-2013, 11:26 AM
67zo6Camaro's Avatar
67zo6Camaro 67zo6Camaro is offline
^^^ that is a super slick setup ^^^
Old 02-15-2013, 03:20 PM
intocarss's Avatar
I was thinking you should just buy a Nextel Cup car
https://www.youtube.com/watch?v=I20MI...6F1DD1B946CD27
OR
http://www.race-cars.com/carsales/ot...27029039pp.htm
http://www.race-cars.com/carsales/ch...45172300pp.htm
Old 02-15-2013, 04:49 PM
Flash68's Avatar
Flash68 Flash68 is offline
Originally Posted by Cris@JCG View Post
I think you did good with the buy on this third member.. If locker does not work then you can swap posi unit... I have one of these units on order..
Thanks. I hope so... If not, make a change!
Dave - What are the performance traits of the Locker that could be a negative in your application?
Negative? Since I don't care about the noise a locker makes and almost welcome it, the only potential negative thing I need to experience myself is the deal on corners of a road course. Some say it's a little sketchy and takes adjustments and getting used to. Most autoX guys love it.
I've said this before, but I chose Jake and went with his full recipe (as close as I can) on his AIX 2nd gen. He spent 3 years dialing it in and did very well in AIX with it, also something that is on my goal list for the next 5 years.
I believe I can use the pump still. Def not an expert either.
Not gonna run a cooler to start. Gonna run a line from pump out back to the return fitting on the housing.
The locker or the tow hook?
Nah, that's unoriginal, just as much fun, and a lot cheaper.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 02-15-2013, 05:17 PM
intocarss's Avatar
Negitive? Since I don't care about the noise a locker makes and almost welcome it
You're like me, I like the noises, whines, and vibrations that a Hod Rod makes.
I say.. If ya can't feel It, smell It or hear It, what's the damn point!
Old 02-15-2013, 05:42 PM
Flash68's Avatar
yeah buddy!!
2014 4 tap Keezer
Old 02-15-2013, 07:12 PM
I agree with Dave and Jerry on the rowdy and rough part. When I put the Mustang in gear - you'd think the tranny or something was going to drop out the bottom -- the whole car goes "CLUNK"! And driving slow through the pits - if you let off the throttle - the rear end bangs and clunks... and the whole experience is just the polar opposite of driving something "normal".... which is exactly what I like about it!
Old 02-15-2013, 08:20 PM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
I have a C&R unit that has a Tru Trac in it with the internal pump .. No problem on the replacement of the locker
Now why would you get a unit like this.. a built in pump for cooler & not run it.. i recommend that you run it.. Also when you vent the diff.. try to run a -10 hose.. it will help with pressure the diff builds.. here is pic of the one I did on Blu...
Cris Gonzalez
Old 02-17-2013, 11:36 AM
carbuff's Avatar
Good to know...
Cris,
Does that cooler get much airflow? Tucked up against the gas tank like that, it's hard to see how much air would get through the fins? Or is the cooling in this case less about flow and more just about surface area to dissipate the heat? You aren't running a temp gauge on the diff, are you?
