Old 03-26-2015, 05:27 AM
grendel grendel is offline
So, opinions on paint?
It was originally pull me over red. When we obtained it, we had every color car under the sun.
Now everything's black.
And I think this thing would be wicked in deep black with carbon fiber accents.
So, candy apple red or deep black? Either will have carbon fiber accents, perhaps even including flares.
I am fixing the quarters, gaps and lead work will be flawless so the car will not have a single dip, orange peel or defect.
My garage builds, with some hack and professional love thrown in:
68 GMC C1500
Haulin more than the mail
73 Camaro
Better grow a mullet
70 K5 - 4wd turned 2wd
Project might as well...
Known as John or "JJ"
Old 03-26-2015, 06:49 AM
Evan Iroc-Z Evan Iroc-Z is offline
Candy apple red with black carbon accents would be pretty cool. However, if you are going for a more subtle look the deep black with black carbon accents would fit the bill.
Personally, I think this car need the red with carbon.
'89 IROC-Z Turbo 3.8 5SPD
LS1 Brakes|Wilwood Prop Valve|LS1 Master Cylinder|Aluminum Driveshaft|LS1 3.42 Rearend|Adj PHB|Adj LCA|LCARB|Koni Struts|Koni Shocks|Adj Caster/Camber Plates|STB|10 Spoke SS Wheels|PHB Relo Kit|Adj TA|SFC|ARAP Based Prom|B&M Short Shifter|Underdrive Pullies|SMOG!|AIR!|Rag Joint!|Magnaflow|Ported Plenum|Misc Stuff
Old 03-26-2015, 10:58 AM
Originally Posted by Beach Cruiser View Post
That Motor looks Healthy!
Thanks. I like it so far
68 GMC C1500
73 Camaro
Old 04-07-2015, 08:51 AM
Starting to think about selling this off.
I have too many projects going and this will do the same thing my Vette will.
68 GMC C1500
73 Camaro
Old 04-18-2015, 06:32 PM
I've sort of been flat on this project, since I got it back.
Here's why:
https://lateral-g.net/forums/showthread.php4?t=49925
Love the pics in that thread?
Now that it's behind me, I've started tear down so I can fix what's needed and move forward. So much for this being ready to race this year.
Here's where we are now:
68 GMC C1500
73 Camaro
Old 04-18-2015, 06:43 PM
Build-It-Break-it's Avatar
Wow, sorry you got scammed . I tried to warn people. Hopefully you'll be able to salvage your build Somehow.
Ahmad B
Old 04-19-2015, 04:53 AM
While I cut off the right quarter, wheel housing (including the DSE piece), repair the damage to the body from removing the filler panel between the rear window and trunk lid - I am sure there's more hiding.
Moving on.
We've kept on the engine build.
We did have to fabricate a front mounted crank sensor. The MagnumXL crank did not have provisions for a reluctor wheel... I bought it cheap. It also kicked off this entire destroked LS thought process.
Transmission's also ready to go. Also had all the exhaust ceramic coated.
Don't worry, will polish the fabricated valve covers
68 GMC C1500
73 Camaro
Old 04-19-2015, 06:25 AM
dhutton dhutton is offline
Looks like you have some work ahead of you. What are your plans to resolve the significant front and rear suspension issues? It almost looks like a scrap it and start over again scenario.
Don
Old 04-19-2015, 06:41 AM
Don
I am talking with Ride Tech (awesome guys) about the front coils/shocks. They have a solution to avoid contact.
The right rear quarters will be cut apart and put together right. Heck, I'll even brace it so the roof doesn't drop while the quarter's out. Novel concept. New quarter, wheel tub and DSE mini tub. They will be welded in place with the back window, trunk filler panel and trunk lid in place.
I talked with DSE (more awesome guys) about their rear links and bought the stuff to bring it back to their specs, which is 3" still narrower than factory. I can use their sway bar, which won't contact the coils. Scott cut their links, after talking with DSE, which DSE did not advise.
The upper rear coil over mounts will move to the inside of the frame, with more help from Ride Tech (Did I mention that Darren's awesome?) using the right shock ends.
I will tie the rear most IRS mount into the Tiger Cage. The rear IRS mount is currently a piece of tube welded through sheet metal.
We'll connect the round tube sub-frame connectors to IRS' front most mount (it's not all the way there).
I am hoping I can heat the bay bar and roll it to fit flush on the frame, after I cut off the flange and weld on a new one.
As for Scott keeping my money for my engine/trans/sub frame he sold, that's between him, God and the law.
So, all in all, not a complete re-start, but probably 100 hours of work and more parts.
68 GMC C1500
73 Camaro
Old 04-19-2015, 11:52 AM
Che70velle's Avatar
Man I wondered when you started this thread if you'd read the feedback left over there about Scott Mock. He is building quite a fan club over at the feedback section. Then I saw your post recently, which you were thinking about selling the project off, and it made me wonder if something had went south between you two. Keep your head up. Surround yourself with quality people, and this car will be finished before you know it.
Thanks Dad!!
