Old 05-25-2020, 02:43 PM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by jmac View Post
No you didn't!
No it is primer
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
syborg tt (05-29-2020), will69camaro (05-25-2020)
Old 05-25-2020, 03:56 PM
colorado80439 colorado80439 is offline
Well if you're going chalk, you might as well go matte
I'm still voting for Hugger
https://hot-cars.org/2017/05/25/hugg...new-zl1-motor/
Old 05-25-2020, 08:26 PM
camcojb camcojb is online now
No it is primer
Old 05-26-2020, 07:51 AM
SSLance's Avatar
SSLance SSLance is offline
No it is primer
Lance
Old 05-26-2020, 08:32 AM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Default GW's 40
Porsche Calk White ?
Same color as GW's 40 right?
Sure miss him...
Ty Ingle, USAF Retired
FREEDOMBIRD
The Following User Says Thank You to OLDFLM For This Useful Post:
ScotI (05-26-2020)
Old 05-26-2020, 11:50 AM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Mark, do you run an expansion tank on the LT4 / LT5 swaps?? If so, what tank has worked for you?
TIA.
Old 05-26-2020, 01:36 PM
Stielow's Avatar
TIA.
For the radiator and the intercooler system I do not run an overflow tank. The radiator has a small amount of air in it for expansion I do run an overflow tank. Not sure the brand. What ever will package. No tank for the intercooler system.
Mark
Stielow Engineering
Old 06-03-2020, 08:33 AM
DKz Garage's Avatar
Mark... I know you run a dry sump in your cars.....As these supercharged motors create a lot of heat - Do you run an external oil cooler, if so, where do you mount it?? TIA
Sorry to be "that guy" with all the questions
Old 06-05-2020, 04:40 AM
Stielow's Avatar
The Dutchboys are done with the final block sanding. Now it comes apart to get put on the rotisserie to prep the bottom and the firewall.
Stielow Engineering
The Following 4 Users Say Thank You to Stielow For This Useful Post:
fleet (06-05-2020), kwhizz (06-07-2020), will69camaro (06-06-2020), WILWAXU (06-05-2020)
Old 06-05-2020, 09:04 AM
Stielow's Avatar
Stielow Engineering
kwhizz (06-07-2020), Sonar Chief (06-05-2020), will69camaro (06-06-2020), WILWAXU (06-05-2020)
