Old 03-11-2017, 09:31 AM
wiedemab's Avatar
wiedemab wiedemab is offline
The only other thing that I've gotten done recently was to work on buttoning up the tail-panel and tail-light areas. I welded up the factory lead seams with silicon-bronze (same as I did at the roof to quarter seam. I still have a little bit of work to do on the tail-light area and then gap the decklid.
Slowly, but surely making progress. One of these years it'll be on the road.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 03-11-2017, 09:58 AM
SlowProgress's Avatar
Thanks for sticking with this project. Love that your saving another one. You are lucky your dad has the skills to help out as well and your metal work is great, something you will have your whole life. For some reason I never subscribed but I fixed that today. Stay motivated!
Old 03-12-2017, 03:45 AM
HEEP's Avatar
HEEP HEEP is offline
[QUOTE=wiedemab;655678] I welded up the factory lead seams with silicon-bronze (same as I did at the roof to quarter seam.
Brandon, Can you explain why you welded with the silicon-bronze on those seams? I think I made a mistake on mine by using my mig.
Bill
My Build Thread;
https://lateral-g.net/forums/showthread.php4?t=40557
Old 03-12-2017, 07:37 AM
wiedemab's Avatar
[QUOTE=HEEP;655705]
I look at it as a way to seal up the joint really well. It's an overlapped and plug welded joint which is what gives it the strength. This is a way to seal up and smooth out the joint while also adding some strength. It should also help with whatever filler you go over the joint with - keep it from flexing as much and showing through the paint (for example when it sits out in the sun and gets hot).
Silicon-Bronze also doesn't have primer/paint adhesion issues.
And to be honest, I'm benchmarking against what the professional shops that I admire are doing. I will also do the seams at the quarter to rocker panel. Not sure if that answers your question.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 08-07-2017, 06:49 PM
wiedemab's Avatar
Default Some updated pics - -
Another idea I stole from DSE - - had these machines for the dash to house the vents for the heat/AC
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 08-07-2017, 06:53 PM
wiedemab's Avatar
Had to do some more splitting to get the gaps at the cowl right - -got the hood to fender gap looking pretty good.
Welded on new pins for the trim clips...
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 08-07-2017, 06:57 PM
wiedemab's Avatar
more parts.
Working on the dash
Still getting the hang of the the silicon bronze -- - got a little messy on the dash vents, but I'll metal finish them out and they'll be good to go.....
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 08-07-2017, 07:01 PM
wiedemab's Avatar
Not running a dash pad - - -
Going to run a Braille battery - picked up this nice little mount from B&B Classics
Still working on the gaps to get them dialed in....
Split the quarter to get the decklid gap corrected at the front corner - tigged back in and metal finished.
More work on the decklid gap - - -
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 08-07-2017, 07:07 PM
wiedemab's Avatar
Mocking up the Racepad IQ3s - I'm not real excited with how it fits (just looks like a racepak stuck on the dash - which is basically what it is), but it'll work fine for now. The damn dash in these cars is pretty small. I don't want to get too hung up on something that I can change out later. It honestly looks a little worse in the pics that it does in person.
Another view - - you can also see the super-fancy steering column protection! --
My little helper - working with me on installing the Ridetech fuel cap - really nice product BTW!
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 08-07-2017, 07:13 PM
wiedemab's Avatar
I went around and around on 7/8" vs. 15/16" master cylinder. In the end -- given that the piston area of the C6 Z06 calipers isn't that large, I went with a 7/8". I can't remember the exact application, but this Chrysler product MC - original application may have been Dodge Shadow or something. They have basically the exact same one in 15/16" if I want to change it out later. I kind of like the OEM look of it and they are dirt cheap (for new, not reman). You have to file the holes a little bit to fit GM spacing...
Got my wheels assembled and mock up tires mounted (Thanks to my friends - Farrington family for some used up BFG Rivals!)
Assembled the front suspension
Put the rear axle in - -
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
