Old 03-01-2019, 06:34 AM
Blake Foster's Avatar
Originally Posted by CJD Automotive View Post
Look at the engine offset!
Coming together and looking good.
Tt is all due to the rack location and oil pan, The way Sweet builds the racks is that when they narrow them, the pinion also moves closer to the center, we ran into this on the Extreme front end and ended up having to use a wider rack to clear the LS oil pan rail which is wider then even a big block.
It is ALWAYS the rack the dictates the placement of EVERYTHING. if you want the geometry correct.
Blake Foster
www.speedtechperformance.com
The Following 4 Users Say Thank You to Blake Foster For This Useful Post:
craig510 (03-01-2019), fleet (03-02-2019), gofastwclass (03-05-2019), slimjim (03-01-2019)
  #272
Old 03-01-2019, 07:19 AM
CJD Automotive's Avatar
CJD Automotive CJD Automotive is offline
Gotcha, didn't realize that about the racks. I thought it was moved over for weight distribution to offset the driver.
Craig Scholl
CJD Automotive, LLC
www.CJDAUTOMOTIVE.com
"I own a Mopar, so I already know it won't be in stock, won't ship tomorrow, and won't actually fit without modification."
Old 03-01-2019, 08:04 AM
mitch_04 mitch_04 is offline
Was the MSD Airforce intake chose because of size or performance? I'm interested in different builders opinions in intake manifolds, why MSD instead of Fast or Holley or....
Old 03-02-2019, 10:29 AM
Because it makes 25hp and 25Tq over the others......
Easy choice
Old 03-02-2019, 12:13 PM
Flash68's Avatar
Flash68 Flash68 is offline
One thing he did appear to get right was the corner balancing and this should have helped I'd think?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 03-02-2019, 07:32 PM
Turbo6inKY Turbo6inKY is offline
Concentrating on one thing to the exception of all others never helps.
Andrew Scott
1987 Buick Grand National
Web Log
Instagram
Youtube
Old 03-03-2019, 07:05 AM
Easy choice
Did they test on this engine or is that from a different test?
Not doubting or anything, just curious! I don't have a lot of money so what I spend needs to be researched well!
Old 03-03-2019, 11:27 AM
No Mitch, no testing here — but if you search the ‘net — the MSD seems to be the current power maker. Lots of info about them - and tests done against others etc.
Old 03-03-2019, 12:45 PM
Che70velle's Avatar
Great to see this thing coming along so well Greg. What electronics will run this engine?
Thanks Dad!!
Old 03-03-2019, 03:18 PM
It’s running a Holley Dominator
