Closed Thread
Old 04-29-2012, 11:03 PM
intocarss's Avatar
Another trick I have heard of but never done myself, is groove the lifter or the lifter bore so you get more pressurized oil onto the roller wheel. And yes it's better to have a little more spring pressure with solid rollers
  #2852
Old 04-29-2012, 11:07 PM
CarlC CarlC is offline
Valve springs? What are those? It's been so long since I've had to tear into an engine I just can't remember.
http:www.vaporworx.com
  #2853
Track Junky's Avatar
Doesn't Morell make the Isky EZ and all other high endurance lifters?
I'm running the PBM RL 955's but I've heard Morell makes those also.
Gaetano Cosentino
  #2854
Old 04-29-2012, 11:11 PM
intocarss's Avatar
You'd be surprized on how just one or two Co's make all the lifters and springs for the other Co's
  #2855
Old 04-29-2012, 11:13 PM
You better knock on some wood.
  #2856
Old 04-29-2012, 11:24 PM
Just checked yellowbullet and there are guys that have run the PBM's for 3 seasons with no issues. $300 bones
Gaetano Cosentino
  #2857
Old 04-29-2012, 11:30 PM
Big Blocks and Small Blocks are a different ball game.
  #2858
Old 04-29-2012, 11:47 PM
Flash68's Avatar
Flash68 Flash68 is offline
You and Pettis talk about oversized lifters?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
  #2859
Old 04-30-2012, 12:15 AM
I honestly don't remember but I know it's something he does on a regular basis. By big block solid roller standards, it's really a baby so I don't think it was a real consideration. Solid roller lifters are a wear item in all engines, especially big block chevys. I knew this since day one and that's why I've kept a fairly close eye on them. The valve spring pressure is likely what led to the failure. That or it's one hell of a conincidence. I've read a bunch of threads on solid roller failures and I don't recall valve spring pressure coming up but I feel it's likely the real issue. One thing to remember is a solid roller has lash while a hydraulic roller rides on the lobe at all times.
Swapping springs and replacing/rebuilding lifters are going to be part of the maintenence and I knew it, just didn't know the interval. It almost bit me.
  #2860
Old 04-30-2012, 12:34 AM
I dont like the idea of gauging by miles driven. One of these days I'd like to install an hour gauge. Probably wouldn't be a bad idea for you either since you do alot of street driving. Just the fact that roller lifters dont like idling would be a pretty good deciding factor.
The guys at NYES told me one season for springs and lifters, 2 for rings and bearings and I told them exactly what I would be doing with the car. Yeah, I had a shaky start with those guys but I do believe they know what there doing and talking about now.
Gaetano Cosentino
Closed Thread
