Old 02-18-2008, 12:56 PM
camcojb camcojb is offline
Originally Posted by Blown353
Hey Jody, what were your EGT's at the fast end of the track? Any trans issues? Did you put a line pressure kit in the tranny?
Also, if a buddy of mind with a 2005 Duramax buys a license can we use your EFI Live? He's had 2 defective Edge boxes in a row and wants to go the EFI Live route.
Remember, I said you'd like diesels...
I have a completely built trans and triple-disc billet lockup converter........... stock stuff with a transgo kit won't last at all with the bigger tunes.
It hits 1450-1500 max which is somewhat high, but no way it'll do any damage in a 1/4 mile race, not enough time. I think my license allows me to tune two trucks, but I promised Brent Dupont he could be the second truck. If your friend gets a license you can use my tuner, no problem. And yes, you said I'd like it, and as usual you were right. You're a pretty smart guy..........
Old 02-18-2008, 01:12 PM
Blown353 Blown353 is offline
1400-1500F isn't high at all given the MPH... I'm impressed. I've seen trucks with programmers have EGT's that high and they only trap around 98-102 mph.
My buddy with the Dodge in the low 11's runs 1800-1900F at the strip... and sometimes 2000F when at the tractor pulls.
I figured you had done something to the trans. The simple valve body mod / pressure kits usually will start throwing P07XX tranny codes at around the 140-150hp level and the converters aren't too far behind that.
Who did you get the tranny from? (BD, Suncoast, etc?) or did you have it built locally?
1969 Chevelle
Old 02-18-2008, 01:25 PM
Made a trip to Los Angeles for an Efi Live Diesel tuning class, and had the trans done while I was down there. Guy named Mike Lovrich (sp) at Inglewood Trans did a Suncoast SCIV trans kit in mine along with one of their new 1058 billet converters.
Old 02-18-2008, 07:29 PM
jeff s's Avatar
jeff s jeff s is offline
Supporting Vendor
I really need to get me a truck like that!
Nice work Jody.
Thanks,
Jeff Schwartz
SchwartzPerformance
Where classic style meets modern technology.
Website : Facebook : Twitter
Old 02-18-2008, 07:34 PM
XcYZ's Avatar
XcYZ XcYZ is offline
You know you want to go 11.99.
My LS7 69 Camaro
Old 02-18-2008, 08:01 PM
Nice work Jody.
thanks Jeff.
you're a very bad influence.............
Old 02-18-2008, 08:16 PM
XcYZ's Avatar
I made this just for you, Jody.
My LS7 69 Camaro
Old 02-18-2008, 08:25 PM
Scott, it needs more black smoke.
1969 Chevelle
Old 02-19-2008, 07:58 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Leave it to your friends to be the bad influence & try spending more of your $$. Somehow though Jody - I don't think you need any influence. When it comes to power you are your own worst enemy!!
When I can I set up an appt for my truck!! Don't need to run 12's though!
Brent
