Old 11-08-2008, 10:19 PM
Thread should have ended at 95% street car.
Old 11-08-2008, 10:30 PM
Flash68's Avatar
Flash68 Flash68 is offline
yeah yeah yeah...
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 11-08-2008, 10:39 PM
Blown353 Blown353 is offline
I look forward to hitting 7000rpm in 5th gear.
LOL... it was a copy/paste from a spreadsheet.
1969 Chevelle
Old 11-08-2008, 10:48 PM
Flash68's Avatar
I hear ya. And thanks for posting it!
2014 4 tap Keezer
Old 11-09-2008, 11:36 AM
bobhamilton15090 bobhamilton15090 is offline
So your 3000 rpm @ 100 mph observation is very close, but at 2K rpm you're going 65.
You can tell I drive at 100mph more than I drive at 65mph let alone 80mph
Did I mention speed limit is 55mph?
Old 08-05-2010, 03:02 PM
sikryd sikryd is offline
I have the same type of question...
I have a 67 Camaro with an iron headed big block, tire is a 275/60/15 for now, and I have 4.10 gears. From looking at speed calculators, it seems that with the .64 unit, I will be doing 73 MPH @ 2300 RPM. With the .82 unit, I will be doing 57 MPH @ 2300 RPM.
I live in Hawaii, and traffic is sh!t on oahu, plus freeways are not very long. So I'm wondering if I should get the .64 or .82... Jeff at Keisler said I should get the .64, but I'm really wondering if that is the correct choice. My cam in the 468 is pretty big, 290/625 108 solid roller, have a single plain intake, and motor is built to go higher RPM. When I built the motor, we had a 1/4 mile track here, but no more.
Old 08-05-2010, 09:15 PM
The WidowMaker's Avatar
if you are buying the overdrive because it has one, make sure you can use it. figure out what your cruising speed will be and then make sure your rpm is high enough for that cam.
"The WidowMaker"
