Old 12-21-2005, 09:12 AM
lsx7 lsx7 is offline
Thumbs up RX7 G-machine
not sure if it qualifies for Pro-touring but its definetly a G-Machine!
1994 Mazda RX-7 R1
01' GM LS-1
Partiot stage 2 CNC ported heads
MTI G1 cam, 228/232 .588 113 lobe center, hardened push rods, adjustable timing set
FAST LSX 90mm intake manifold and throttle body
Ford SVO 36lb injectors
Factory GM ecu tuned with HP Tuners
T-56 trans
Exedy Hyper Twin plate clutch with cromoly flywheel
Custom 4" aluminum drive shaft
Custom Hinsons mid headers
3" y pipe to 3.5" with Stainless Works resonator and rear muffler
Hinsons front engine cradle
Jim Labreck's rear Cobra Diff brackets
04 Cobra Alum rear diff with 3.55 gear DSS Chromoly axles
Rotary Extreme, toe and control links,
Tein Adjustable Suspension
CCW 18x10 wheels with 285-30-18 Pilot Sports
New Mazda ball joints
All Prothane engine and trans mounts
99 spec front bumper
everything works A/C, all Factory Gauges and has power steering
500+ hp and 2800lbs!
weight distribution is still 50/50 frt/rr
Rob
