Old 08-31-2011, 09:34 PM
Let me guess, Renner showed up for a photo op and will be in touch with a small project.
Old 09-01-2011, 07:09 AM
Payton King's Avatar
Default Not sure how you are going to proceed
But I would leave the sheet metal bolted up and drop the subframe out the bottom. Assemble the other with the motor and headers and roll it back in. I have done a few this way and it is much easier.
Nice progress!
Old 09-01-2011, 09:30 AM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Originally Posted by DJW32 View Post
I've never heard of Pomona valley customs. Did they do good work? Would you go back?
I still need to inspect the frame rails. Howeve,r from the trunk view they did a great job. Yea I would go back. I actually was/am tempted to use them for the TCI parts install too. While I was there they had quite a few cool projects in the shop. A Nova II with a TCI front clip. A Nissan Z with an LS install, some 50's Buick getting bagged and dropped with a C notch in the rear frame rails. A few other cars I didn't ask about.
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 09-01-2011, 09:33 AM
Nice progress!
I planned to leave the sheet metal intact. However I'm open to advice on how to do it. I would love to be able to roll the new clip with motor and trans bolted up but am not sure how I'd lift the body high enough to clear it while supporting everything properly? Any ideas? Without the motor it will be easy enough. It's the with motor part that is tougher.
Old 09-01-2011, 09:40 AM
Haha good guess but not what happened. Doug saved my bacon. I originally was going to do the work with just me and my buddy Jason bu after he was 3+ hours late I started get g worried and Doug answered my call for help. Ended up going a lot smoother with 3 people. Well except the part where we dropped the trans down with the shifter and ball still attached...
Old 09-01-2011, 10:12 AM
70rs's Avatar
70rs 70rs is offline
Take the front clip off as a unit (the sheet metal). Much easier that way.
Roll the old frame out,roll the new frame in, bolt the front clip back on. No lifting of the body,less chance for accidents or damage and its only a little extra work.
Eric
Old 09-01-2011, 10:13 AM
KPC67's Avatar
KPC67 KPC67 is offline
cool car, and cool updates.
Kevin Carter
Old 09-01-2011, 10:26 AM
Track Junky's Avatar
Get a hold of Scott (XcYZ), thats exactly how he did it. He has a build thread on it also so you may want to dig it up.
Gaetano Cosentino
Old 09-01-2011, 10:36 AM
Flash68's Avatar
Flash68 Flash68 is offline
Nice work Chad. I'm sure some of your neighbors are impressed.
You called that a Champ pan.... does Autokraft just "rebadge" them?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 09-01-2011, 11:38 AM
I will keep this in mind. Due to space limiations it may be easier to keep the clip bolted up to the car so I don't have to find a place to set it for any length of time.
Thanks! Appreciate that.
Cool. I will do some searches to see what I can find.
Thanks Dave. Yeah Autokraft and others (such as Prodigy) just rebadges the champ pan. Advantage of buying an autocraft or prodigy pan is ease of ordering and the fact they include the correct pick up and oil filter adapter without making you search for the part numbers and buy them individually (the way Champ sells them).
