Old 11-22-2011, 07:31 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
That's not correct. The G Bar was a joint venture between Air Ride and Chris Alston. Basically and air bar with varishocks. The prodigy bar is the same but with QA1 end links everywhere except the front spring pocket. The G Link is a fresh design from Chris Alston solely.
What I can tell you is that I purchased a Prodigy bar from Frank and what arrived was the G-Link from Alston. That tells me that what Frank is selling as the Prodigy Bar is actually the G-Link. That said, I understand this suspension has been undergoing a number of improvements recently.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 11-22-2011, 07:53 PM
realcoray realcoray is offline
You mean G-Bar. There are two different generations of Alston things, the G-Bar which is what the Prodigy Bar is based off of, and the G-Link which is similar but different.
The G-link doesn't need it's bearings changed in general because they have spherical already (except maybe the lowest variant). The Cradle is vastly different and I believe offers much more adjustment.
Old 11-22-2011, 09:03 PM
I'd have to talk to Frank but what I said is on the money since I can't imagine Frank is making any changes to the G Link. It has the trick end links and adjustments.
The Prodigy Bar is a G Bar with different end links that will last. I tore out the factory end links my 1st autocross.
Old 11-22-2011, 09:16 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
Default chassisworks g-bar & g-link difference
I'm not sure what Frank has but the major difference is the Chassisworks g-bar has poly bushings for the end links the Chassiworks g-link has pivot balls for the end links. Both systems are available with either air springs or coil overs
http://cachassisworks.com/c-340-cama...gm-f-body.aspx
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 11-22-2011, 09:20 PM
G Bar(Mustang Photo)
http://scandc.com/new/node/534
Prodigy Bar
https://lateral-g.net/forums/showthread.php4?t=16153
G Link
http://www.cachassisworks.com/gBar.html
Using G Bar due to marketing.
I bought my G Bar in 2007. I don't want to sound like a prick, but I know what I'm talking about. HA HA
Old 11-23-2011, 07:47 AM
6D9 Matt's Avatar
6D9 Matt 6D9 Matt is offline
Yeah check out Vegas's project thread... he knows every inch of his car which includes a 4-link stated previously. Hes been through this a couple of times Im sure.
'69 Camaro
416ci / T56 / 9"
Turbo in the works...
Old 11-23-2011, 10:36 AM
67XR7's Avatar
67XR7 67XR7 is offline
if you get on their website and look at the pictures you will see that they are using a fab 9 housing which has a ton lower mounting points for the coil over. you want to maintain shock travel as its a good thing! im sure with the various housing mount points and a tiny bit of coil over adjustment you can get the ride height desired.If you already have your rear end "built" im sure the shop or your self could order these brackets and weld them on. hope this helps.-JEFF
Old 11-23-2011, 12:44 PM
Rybar's Avatar
Rybar Rybar is offline
The kit can be ordered with the brackets to weld to your own rear end. The springs are too long for a super low ride height and the fact that the cross bar sits under the stock trunk floor makes them sit in a lower position vs the DSE which has the shock cross member and mounts the shocks higher up so you can still sit low and have the correct travel. Sorry I'm not a suspension engineer but that is the thought in my head. Here are pictures of the Alston G-Link as Todd stated it is different than the older G-bar/Prodigy bar.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 11-23-2011, 06:37 PM
pokey64's Avatar
pokey64 pokey64 is offline
For what it's worth here's a pic of our G-Link and Fab9. These were bought form Prodigy last winter.
//Ed
//1964 Impala SS
//1966 Chevelle (Family Hauler)
//1969 Camaro (Hers...)
Old 11-23-2011, 07:05 PM
frojoe's Avatar
frojoe frojoe is offline
You wouldn't happen to have any pics of full compression with frame-to-axletube clearance, would you?
Thanks anyways for those pics tho!
Joe
1972 Nova with twin 6466's and T56 Magnum in the works. Speedtech, Ridetech, Wilwoods etc. Swap thread --> http://ls1tech.com/forums/showthread.php?t=980909
