Old 11-18-2012, 06:57 PM
Track Junky's Avatar
If your looking to save some money just change out the pressure relief spring in your stock pump to the Z/28 spring. This will give you standard volume but bump pressure up to 60-70 lbs. The stock sring is good to about 55 lbs and in my opinion that isn't enough if your spinning to 6500 rpm.
Just remember the rule of thumb.....10 lbs of hot oil pressure for every 1000 rpm.
Gaetano Cosentino
Old 11-19-2012, 12:03 AM
intocarss's Avatar
https://www.cantonracingproducts.com...ion&key=22-150
Old 11-21-2012, 09:12 PM
musclecarmatt's Avatar
musclecarmatt musclecarmatt is offline
thats a good idea....contacted canton racing and they reccomended the 15-250 pan along with their matching pickup.....if i installed the 15-250 RR pan w/pickup,high pressure spring,and install accumsump...that be a good budget upgrade over stock..
1971 Chevrolet Camaro RS-Detroit Speed Equipped with PTFB chassis Bracing..autox specified.
1966 Chevrolet C-10-Driver/Project truck
My Garage:http://www.facebook.com/pages/Bellam...22910454430687
Old 11-22-2012, 01:18 PM
Bryce Bryce is offline
I talked with canton, moroso and milodon at SEMA. I will begoing with the Canton. THe trap doors and shelf looked great. Moroso looked good too and they have billet rails and can build it out of aluminum. I was looking for a SBF pan but the engineering is probably the same.
