Old 03-01-2013, 05:39 AM
usa-69z usa-69z is offline
David , yes the diff will be at 55 " ,,I have already got a moser rear custom built a few years back and will now have to have it narrowed to suit.. also the g bar rear needs the mounts welded to the diff. No big deal , just im impatient and i wanna drive the thing sooner than later..
Originally Posted by Stovebolter View Post
Tony,
So a 1969 Camaro stock hub to hub is 60"? I was told the Z28 is 58"? Are they different for different X codes? Just asking.
Gav,
As Vince suggested, brakes also may play a role. I'll probably go with the stock width rear and stock dish making replacement a cinch. I'm going with Moser full floater (steel hubs) and PBRs on Willwood GT rotors. GMR makes the mounts for the PBRs and a sweet little parking prake optiion. At 58" as a standard width it will be easier to get a replacement if needed. I'm sure Moser can and will make any width but they have specific widths already in stock. And from what I see they have good prices. Are you dead set on keeping the 12 bolt? Just a thought.
David
David
69 CAMARO - RIGHT HAND DRIVE AUSSIE MODEL.
383 SBC 8 STACK INJECTED EFI.
RIDETECH FOUR LINK REAR - DSE MINI TUBS .
SPEEDTECH FRONT A ARMS & COILOVERS.
MOSER 3.7 REAR- 6 SPEED T56 TREMEC.
FIKSE RIMS ETC ETC..
Old 03-02-2013, 06:42 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
Generally speaking you want to select the wheels with the offset you like first. Then mock them up under the car to determin the WMS to WMS width of the rear end. Here is a good post on exactly what the WMS measurement is and how to measure it. Just for the record, my rear wheels are 18x12 with a 5.9" back space. I mocked them up under the car where I wanted them and determined that I needed a 57" WMS to WMS rear end.
http://www.pro-touring.com/showthrea...Mount-Surface)
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 03-13-2013, 06:19 AM
468Camaro's Avatar
468Camaro 468Camaro is offline
Needs to be said that not All rims come in . The backspace that you may want..and not All rims can be custom ordered..which is why you want your rims first.. Ever see a car with the rear tires "in too-far" cuz the builder narrowed the rear to much for the desired rims..
Bowtie Nutt 68 Camaro Pro-Street 2x3 Ladder bar -backhalf 32x14 Dana 60 5.38, 406" 12-1. .Chet Herbert Billet Roller .645" 106' .Brodix Trk1, 830" Annular,Victor.glide-brake.. Needs Real windows.. 1989 Vette Z-51 357" 4bolt Forged, Dart IIS,Comp cam..Billet Specialties, 86" Iroc-z 468-400 ,2003 Roadstar 102" ..
