Old 05-24-2013, 05:01 PM
Sieg's Avatar
Sieg Sieg is offline
Originally Posted by spooty View Post
While its true the newest breathers have a spring-loading and can hold a small pressure....it is quite small and certainly well below 10 psi.
The spring loading is there to avoid splash- entry and not for seal function.
6-7 psi was what the Tremec tech advisor told me.
Old 03-20-2014, 12:34 PM
dontlifttoshift's Avatar
What shifter doesn't leak?
Anybody else had problems with the factory tremec shifter?
Donny
Old 03-20-2014, 12:42 PM
parsonsj parsonsj is offline
The latest design White Lightning shifter (from American Powertrain) doesn't leak.
The first several iterations did.
The factory shifter rattles, rather badly, no matter how much I shim it.
John Parsons
Old 03-20-2014, 12:44 PM
White lighting is confirmed dry....even on track?
Donny
Old 03-20-2014, 12:48 PM
Dry as a bone in my customer's car. He's had several months with it now with perfect results... but he doesn't go to the track.
Edit: the earlier ones seemed to leak only in high RPM conditions, and I tested the latest one (hard) in that sort of situation. The new seal sure looks impressive.
John Parsons
Old 03-20-2014, 02:28 PM
Roberts68 Roberts68 is offline
Donny, did you see my post #16 with the pictures of the WL generations I had in my possession for awhile?
John, can you confirm if the one in your customers car looks like that third one? From memory I mean, I do not intend for it to sound like I would ask you to look at it.
Thanks,
Robert
Old 03-24-2014, 01:10 PM
GMJim's Avatar
GMJim GMJim is offline
Originally Posted by carbuff View Post
Jim,
I also welcome you to the site. Already great to have manufacturer representatives here to help us out!
Regarding my question below, any insight?
Thanx!
Sorry for the loooooong delay getting to this thread. I've been busy with new projects.
Hurst Driveline DOES sell parts individually and ships them FREE. Some parts that are contained within an assembly are not available separately unless you have the assembly and it has a broken or worn out part. An example would be if you want a hydraulic master cylinder mounting bracket that is normally sold as a kit and you need a new bracket to replace one for what ever reason we would sell this to you without question. If you want to purchase just the bracket and don't have our hyd kit we don't sell the bracket separately. Reason being it won't fit most other hydraulic master cylinders and we wind up getting it back for a refund. If anybody has any questions please contact me. I'll be happy to help you with what you need.
Jim
Old 03-24-2014, 07:26 PM
Yes, that's the one. I've installed it in two customers' cars now, though only one is on the road so far.
John Parsons
Old 03-24-2014, 09:56 PM
I still can't believe these manufacturers make parts and don't test them. It's beyond me....
Old 04-01-2014, 08:53 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
Mr Goodlad,
I currently have a T56 Magnum with the stock Tremec shifter and I'm interested in upgrading to the Hurst Blackjack shifter. But I don't see any reference to an individual part number for the just the shifter. My question is, is the Blackjack shifter available separately or is it only sold with a kit? If the shifter is available can you tell me what part number I would need to order?
Steve
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
