Old 11-29-2014, 09:35 PM
markss28 markss28 is offline
Originally Posted by Rod P View Post
what spring did you order?
I have no clue. MCB said that Ridetech decides that based off my specs. I'll be calling them on Monday to verify before they ship. From what I've researched it seems that 550-650 is a good rate. I know u said 700 so maybe they will recommend that. I just need to make sure it will be a good balance for when I order the rear 4 link. Should have that ordered by March.
Never Stay Stock
Old 11-29-2014, 10:24 PM
Rod P's Avatar
Rod P Rod P is offline
ummm OK...you do know I work for RideTech....
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 11-30-2014, 10:24 AM
Yea I kinda thought u did.
Still they didn't recommend anything when I ordered. I'll call on Monday to make sure tho. I know u stated 700lb on a leaf spring car but what rate for a 2nd with coilovers on all 4? I'll be changing over to the 4 link in a few months.
Never Stay Stock
Old 11-30-2014, 12:53 PM
Rod P's Avatar
700 front, and when you go 4-link I would do 225 rear .......ride quality comes from the shock settings...I suggest the 700lb springs because it will require less preload on the spring, therefore less coil bind, more travel, better handling
Rod Prouty
Bangshift Stories
Old 11-30-2014, 07:56 PM
[thread jack on]
That's a great action picture of you and the car, Rod.
[/thread jack not on]
Old 11-30-2014, 09:44 PM
Vince@Meanstreets's Avatar
what are your current vehicle weights?
. All will be calculated with vehicle weight. A 3000 lbs car will take less than a 4000 lbs car. It's all a package. As you know. Then there is chassis stiffness and sway bars.
[thread jack on]
[/thread jack off]
. Haa Haa trey, you said... Never mind.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 12-01-2014, 09:55 AM
bobbya312 bobbya312 is offline
[QUOTE=badazz81z28;583218]Mark,
If youre interested, I'm going to be picking my 78 Camaro apart here Mid December. It has a complete Hotchkis Suspension and has about a couple thousand miles on it. Hotchkis Upper and lower control arms, Hotchkis tuned Bilstein shocks.I also have the Hotchkis Sway bars.
If OP doesn't buy, I am a serious buyer- I left you a P.M. with an e-mail address
Old 12-01-2014, 08:46 PM
damn! I'm a dumbass.
Old 12-01-2014, 10:32 PM
[QUOTE=bobbya312;583677]
Originally Posted by badazz81z28 View Post
Mark,
Looks like the OP hit the button for strong arms. I sent you a pm
Old 12-02-2014, 06:36 PM
badazz- didn't get a PM or an e-mail. I'm interested in the control arms and sway bars.
