Old 09-30-2016, 07:20 AM
dolf dolf is offline
Default 315 square set up on 1st gen Camaro
Anyone have pics of this being done? Thinking of going to a 315 or 305 front tire and 315 rear. I will be using extended arms for the front to keep the suspension geometry designed in to my subframe. Only people I can find are Blu Balz and the Gulf SCCA CP Camaro. Seeing Hobaughs 65 Vette has made me rethink the build and want a little more tire up front.
Old 09-30-2016, 04:45 PM
Rod P's Avatar
Rod P Rod P is offline
^^^ what's that?
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 09-30-2016, 05:36 PM
Longer control arms. Rather than using backspace on the wheel to extend the track width you can use a longer control arm to keep a zero scrub radius.
Old 09-30-2016, 06:36 PM
Rod P's Avatar
okay
Rod Prouty
Bangshift Stories
Old 09-30-2016, 10:36 PM
Flash68's Avatar
Flash68 Flash68 is offline
So you're going to flare it in some way then?
The new Sutton / SpeedTech subframes people are installing right now will be having some 315 squared setups I bet.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 09-30-2016, 10:52 PM
Air-bender Air-bender is offline
Larry Woo has this on his 68 and it looks very nice.
Old 10-04-2016, 07:36 AM
Blake Foster's Avatar
Yes RedZed our shop 69 has 315 on the front an rear (could fit 335 in the rear. NO outer fender mods. we also have a 67 we are building same 315 on the front NO outer fender mods. Both use our wide inner fenders NOW AVAILABLE!!! we have a customer with a 67 and JCG wide front fenders that has 335 on the front and rear.
Blake Foster
www.speedtechperformance.com
Old 10-01-2016, 07:01 AM
rocketrod rocketrod is offline
.... I will be using extended arms for the front to keep the suspension geometry designed in to my subframe....
If you are referring to extending your UCAs & LCAs, that will cause more problems than it will solve AND you will still have to widen your fenders and get an aftermarket subframe as previously mentioned.
Why do you think you need 315s up front?
Rod
1969 Camaro - LS2/4L70E
Old 10-01-2016, 08:21 AM
Yeah, Larry also has some really nice custom fabricated inner fenders that tie all his other mods together.
This is not done easily on a first gen! I have a 275 rival on the front of my 67 with a DSE sub and a lot of fabrication time was spent on my inner fenders to make them fit and not rub.
Old 10-01-2016, 09:22 AM
Rod P's Avatar
I will be using extended arms for the front to keep the suspension geometry designed into my subframe.
I was just waiting to see if he had a plan, for longer control arms and pivot point correction along with bump steer control, I have 275s on the front of my car on 18x10 rims, I'm pretty good at suspension stuff and I'm at the limit of the stock frame and fenders, but I am interested to see what you have in mind
Rod Prouty
Bangshift Stories
