Old 04-29-2016, 08:08 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Default NEW- Chevy 12 Bolt - "Bolt-On" C6/C7 Hybrid Floater
C6/C7 Hybrid Floater System -
[SIZE="4"]Installs onto GM 10/12 Bolt (except Impala or Truck)[/SIZE] rear-ends,,,,, BOLT-ON!
That's right, you can use your current GM 10/12 Bolt rear-end housing, NO welding & simple installation!
Advantages:
  • Bolts to GM 10/12 Bolt housing end / brake flange (except Impala or Truck)(Big Ford application also available! https://lateral-g.net/forums/showthread.php4?t=49657 )
  • Eliminates the weak/dangerous factory c-clip axles
  • Reduces/eliminates brake “knockback”
  • Eliminates axle deflection
  • Wheel & tire remains intact should an axle failure occur
  • Front or Rear Caliper / E-Brake Cable Positions
  • Utilizes the robust, zero maintenance C6/C7 ZO6 Hub Bearing Unit
  • Utilizes OEM C5/C6/C7 Corvette, and 5th Gen Camaro brake kits
  • Utilizes aftermarket C5/C6/C7 Corvette, and 5th Gen Camaro brake kits
  • Utilizes your existing BAER / WILWOOD caliper & rotor (some restrictions apply)
  • Super compact design compared to traditional style full floaters
  • All advantages of a traditional style full floater without the maintenance
  • Replacement parts available at local GM dealer or local parts house
  • No modifications required to the hub bearing unit as other kits in the marketplace
Note: this applications will add 1/16″ per side to your existing wheel mount surface (based on an existing 2.810″ axle/brake offset)
Fitment: OEM 10/12 Bolt Rears: 67-81 Camaro, 64-72 Chevelle, 64-74 Nova
GM 10/12 Bolt Bolt-On “Base Kit” (pictured below)
GM 10/12 Bolt Bolt-On “Base Kit” (pictured above)
Base Kit Includes:
• (2) Billet Steel, C-Series, Hybrid Floater Adaptors
• (2) Billet Aluminum Caliper Brackets
• (2) C7 Corvette, SKF 33 Spline Hub Assemblies
• (1) Install Kit
• (2) Hub Spacers
• (2) Billet Aluminum Hub Cap Seals
________________________________________
PRICED AT - $1498.00
Add Axles - $400.00
• (2) Hy-Tuf Full Float Axles
Add E-Brake items - $325.00
• (2) C5/C6 Corvette Complete E-brake Assemblies
• (2) C5/C6 Corvette Parking/E-brake Cable Brackets
Have interest?
Have questions?
Need more info?
Dealer Inquires Welcome!
Below pics of the assembled "Base Kit".... (attached 10/12 Bolt End is for display purposes only)
Below pics shown with optional C5/C6 E-brake Assembly & E-brake Cable Bracket. These two e-brake items are optional and the system can be run without and added at a later date if desired.... (attached 10/12 Bolt End is for display purposes only)
Few pics below of this 10/12 Bolt Kit in action!
Old 04-30-2016, 01:09 PM
SlowProgress's Avatar
These are some pretty cool products you have. If they were avialble 2 years ago it probably would have changed my build direction. Good luck with all the new ideas!
Old 04-30-2016, 04:57 PM
did you not already have a bolt on kit developed ? if so whats the difference
Old 04-30-2016, 06:05 PM
Hello Ryan,
Yes I do have another bolt-on application, however the other one you are referring to is specific to Big Ford Ends.
This one is specific to Chevy 12 Bolt OEM style End.
If I recall correctly, you currently have a Chevy 12 Bolt with OEM style Ends
Jay
Old 04-30-2016, 07:47 PM
Hey Jay
Yes I do have a 12 bolt.... I was positive you had another 12 Bolt , bolt on kit .....anyways I keep getting other parts instead of Your ..."rear end " lol kit ...I will be buying the weld on kit regardless
Old 05-02-2016, 11:48 AM
19,69camaro 19,69camaro is offline
I'm interested in the 12 bolt kit. Not ready to buy right away but I would like the option over other alternatives.
Old 10-01-2016, 03:48 PM
Default October Special!
FREE Shipping & PayPal through October!! ("lower 48" only)
Advantages:
Base Kit Includes:
• (1) Install Kit
• (2) Hub Spacers
Add Axles - $400.00
Have interest?
Have questions?
Need more info?
Old 10-19-2016, 07:44 AM
Advantages:
Base Kit Includes:
• (1) Install Kit
• (2) Hub Spacers
Add Axles - $400.00
Have interest?
Have questions?
Need more info?
In Stock!
Old 12-27-2016, 11:50 AM
jonathonar89 jonathonar89 is offline
Very interesting kit. I haven't come across this product until joining this forum. I take it, this also changes the bolt pattern to late GM metric pattern?
Old 12-27-2016, 02:08 PM
Yes ....and if you have aftermarket spindles that have c6 hubs you now have a matched set ...
