Old 11-28-2006, 07:16 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Originally Posted by Van B
Oh, by the way, I have a minitubbed 67 and my rear wheel is 11 inches wide with stock width rear end and 6 7/8 inch backspace on the wheel.
You need to figure some clearance for the sidewall of the tire. Look at the section width of the tire you plan to use. Subtract your rim width from the section width. Half of that number will be how far the tire will stick out from the wheel. Keep in mind that there will be some sidewall flex on cornering.
Follow this advise. Some measureing (which you've done), a little research on tire specs and some simple math will tell exactly what you need.
Old 11-28-2006, 04:03 PM
WicKeD_SS's Avatar
WicKeD_SS WicKeD_SS is offline
Originally Posted by awr68
Yes .5" TIRE clearance is fine but the minimum. What size tire are you going with?
Are you wanting a reversed lip design or standard lip wheel...Intro only offers up to 10" wide wheels in there reversed lip wheels, although for a ton more they will weld two hoops together to go wider. Were they possibly telling you the wheel only comes in a 10?
For what it's worth I have a 18x11.5 wheel and a 315/30/18 tire on my 68 w/ only a 2.5" mini-tub.
If you are stuck on Intro wheels give HvyDeez a call, they are easier to deal with, they are who I used for my Intros.
Thanks for the advise, do you have any pics of your car. Would like to see the 18 on the back, or the whole thing.
WicKeD
Old 11-28-2006, 04:10 PM
mdprovee's Avatar
mdprovee mdprovee is offline
Not sure if it will help, but here are pictures of when I had my 67 camaro mini tubbed.
I am running 11" wide wheel, 5 1/2" backspacing. I had my rear end shotened.
http://hometown.aol.com/gumbydmit22/mpcamaro.html
Mike
Old 11-28-2006, 04:29 PM
WicKeD_SS's Avatar
Yes! any pictures will help out alot.
WicKeD
Old 11-28-2006, 05:42 PM
Shawn Strunk Shawn Strunk is offline
Default I have intro 12" rims on my car
Sounds like you got the info you need but I just wanted to tell you I ordered custom 12" rear rims for my '69 Camaro from intro. Dave is hard headed and doesn't want to sell you something that might not work. Go to members and to Shawn Strunk's '69 Camaro to check out my car.
Old 11-28-2006, 08:02 PM
WicKeD_SS's Avatar
yeah i noticed that hehe. Ill check it out right now. thanks!
WicKeD
Old 11-28-2006, 08:12 PM
awr68's Avatar
awr68 awr68 is offline
Look here, some pics on page 1 and others on page 3....enjoy!!!
Tony
'68 Camaro
Old 12-01-2006, 10:39 AM
markss28 markss28 is offline
I say order from Intro because they look cool and are great rims. I would just order them the way I need it with the right back spacing and width. They will send you exactly what you ordered just make sure your right on the demensions.
Never Stay Stock
