Old 04-20-2008, 12:40 PM
Hammer Head Hammer Head is offline
Updated list & prices..
> 1st gen bucket seats. Clean seats w/ only drivers side having tearing by the handle. Passanger side missing side trim. $20 for the pair w/out tracks plus s&h.
> RDS 6 disc CD player from an '03 for sale. They go on Ebay for $75-up plus s&h all day. $50 plus $15 s&h.
> Set of 4.8/5.3 heads. $80 plus s&h
> Wilwood Superlite Caliper Pair (RIGHT & LEFT) PN 120-7477R/L. New in box. (Summit's PN WIL-120-7477R/L) $250 for the pair plus s&h.
> LSx valve cover extenders w/ longer bolts. Fits '99-up heads. $80 plus $10 s&h.
> LQ9 intake minor smoothing, tapped & plugged. Cannot use Vortec engine cover (mounting has been shaved off). No throttle body, sensors, fuel injectors or fuel rail. $25 plus $20 shipping.
> LS1 windage tray from an F body. Should fit all LSx. $5 plus $10 shipping.
> 4.8/5.3/6.0 Harmonic balancer/ pulley. Fits all LSx using truck brackets. $15 plus s&h.
> LQ9 valve springs (NATURAL METAL). 500 miles! Good to .490-.510" lift. $15 plus $10 shipping.
> K&N Heat Shield for 4.3 Vortec S-trucks '96-up. $15 plus $15 s&h.
> OEM 4.3 intake hat & hose. $5 plus $12 s&h
> OEM coil fits '96-up 4.3/5.0/5.7 vortecs (non-LSx) $5 plus $10 s&h.
> Heater controls for '98- up S trucks w/out A/C, heated mirrors or rear defrost. I was going to use this when I deleted my a/c but I decided not to replace my original. Anyways, it's a little rough & I was mostly going to use it for the face. The back plug in is cracked, the knobs are a little dirty & in rough shape. This is pretty rare because almost all trucks have A/C in them. $5 plus $10 shipping.
> 7.5/7.625 drivers side backing plate for drum brake setup, should fit all chevy 10 bolt rears (8.5 included). $5 plus $12 shipping.
> Master cylinder & proportioning valve from a '92 Astro. $10 plus $10 shipping.
> Spreadbore to squarebore adapter. About 1.5" spacer. For four barrel carbs. $9 plus $10 shipping.
> Squarebore spacer. About 1.5" spacer. For four barrel carbs. $9 plus $10 shipping.
> 7.5/7.625 OEM rear end covers. $5 each plus $10 shipping.
> Auto Meter Pro-Comp fuel level gauge compatible w/ GM sending units. New in box! Summit currently sells them for $35.99 plus $9 shipping, that equals about $45. ..I just want $20 plus $10 shipping.
> Chrome alternator bracket for a SBC/4.3. $10 plus $10 shipping.
> OEM head units. I have two to choose from. One's an AM/FM & a tape player & the other is just plain old AM/FM. If you'd like a pigtail of wire off the stock connector I only have one left. $5 each plus $10 shipping.
> 2 brl Rochester, elec. choke. needs a rebuild. $9 plus s&h.
> Triple gauge kit w/ chrome mounting bracket. Mechanical gauges. Coolant temp, Oil pressure & an Ammeter. $10 plus $10 shipping.
> 11/32 single groove valve locks part#601-16. These fit chevy small blocks & 4.3s among other engines. This is for one brand new set of 16. I have two sets. $8 plus $10 shipping.
> 8.5" open carrier w/ 3.08 gears. $20 plus s&h.
> Cast exhaust manifolds from a late 70's Camaro for S10 V8 conversion. No AIR injection fittings on these manifolds. I can clean & paint them black for an additional $10. $15 plus s&h or $25 plus s&h (cleaned & painted)
> OEM 700R4 torque convertor. Was behind a V8 not a V6. $9 plus s&h.
> Header reducers 3" to 2.5" slanted. Mostly used w/ center dump headers. $10 plus $10 s&h.
> Header reducers 3" to 2.25" straight, 3 bolt flange not included. $5 plus $10 s&h.
> Header reducers ball & socket style. 2.5" to 2". 3 bolt flange not included (requires 2.5" flange) $5 plus $10 s&h.
> GM 1962-1974 NOS Cap, rotor & capacitor All AC Delco & everything but rotor is in original pkgs $20 plus $10 s&h.
> 2 V belts to choose from. One is 34.5" & the other is 45.0". Each is $5 (or get both for $10) plus $10 s&h.
> Screw-in Rocker studs. 3/8" top 7/16" bottom. These are used. They were made by GM. $25 plus $10 s&h.
> 90s-00s Pontiac Grand Prix Shifter just the shifter & boot. $15 plus s&h.
> K&N Round Air filter. 9.5" diameter x 2.75" height. $5 plus $10 s&h.
> SBC header gaskets their seperated & manufactured to just slide in once the headers are in loosely. $10 plus $10 s&h.
> Parts here for Pontiac V8 engines sized 301-455 '66-up. Edelbrock Performer intake $30, used alternator $5, remanfactured aluminum pump $15, remanufactured starter $15, NEW in box hi-performance harmonic balancer $40, NEW in box Hi-performance cam & lifter set (288/298 .444/.466). $90... plus s&h
> Datsun R200 open rear w/ half-shafts. It's a 3.90. $25 plus s&h!
> Datsun 240Z Grille. Great condition. $10 plus s&h.
> Datsun alternator. $5 plus s&h.
> Datsun vacuum brake booster. $5 plus s&h.
> Pontiac Catalina gauge cluster. 1976 & has a cracked face that can be replaced. $5 plus s&h.
> Finned rims. 4 lug 4x4.5 spacing.. they fit early chevy IIs & Datsuns among other vehicles. $50 plus s&h!!
I will consider best offers on all parts!
Need parts? I've problably got it.. http://www.s10planet.com/forum/showt...2425#post72425
1972 Datsun 240Z (AKA the car from www.Fastassdatsun.com.. site is now somewhat back in action)
2002 Chevy S10 Xtreme
