Old 06-12-2007, 02:38 PM
Hammer Head Hammer Head is offline
Default Misc Parts & parts to make a 383 for Sale
Any parts you'd like pictures of just ask. Postal money order prefered, cash & other money orders accepted. Everything gets shipped out USPS Priority (2 days) whenever possible. I also sell hunting/camping knives. I have a big supply of folding knives $5-10 each. I'm currently running a sale on them, buy 2 & get the 3rd one of your choice absolutely FREE. If interested in anything please PM me, I don't read email & it'll all get deleted! Also, this is pretty much everything. I have '65 corvette rams horn exhaust manifolds & various Datsun 240 pieces.
> Early to Mid 90s Ford Taurus electric fan. 3000 cfm+ flow. $45 plus s&h.
> Brand new set (alternator & crank) of under drive pullies for '86-'92 F bodies w/ the 305/350. MACperformance Part # 4400. $35 plus $10 s&h
> Wilwood Superlite Caliper Pair (RIGHT & LEFT) PN 120-7477R/L. New in box. (Summit's PN WIL-120-7477R/L) $300 for the pair or $160 each, plus s&h.
> '89-'93 Cadillac taillights (pair) one is in excellent condition the other has a cracked lens that's easily replaced. $35 plus s&h
> '89-93 Cadillac taillight (single) excellent condition slightly different style from the pair. $20 plus s&h.
> LSx valve cover extenders w/ longer bolts. Fits '99-up heads. $80 plus $10 s&h.
> LQ9 intake minor smoothing, tapped & plugged. Cannot use Vortec engine cover (mounting has been shaved off). No throttle body, sensors, fuel injectors or fuel rail. $30 plus $20 shipping.
> LS1 windage tray from an F body. Should fit all LSx. $9 plus $10 shipping.
> 4.8/5.3/6.0 Harmonic balancer/ pulley. Fits all LSx using truck brackets. $20 plus s&h.
> LQ9 valve springs (NATURAL METAL). 500 miles! Good to .490-.510" lift. $20 plus $10 shipping.
> K&N Heat Shield for 4.3 Vortec S-trucks '96-up. $20 plus $15 s&h.
> OEM 4.3 intake hat & hose. $10 plus $12 s&h
> OEM coil fits '96-up 4.3/5.0/5.7 vortecs (non-LSx) $10 plus $10 s&h.
> Front coil springs made for big block S10 swap. $55 plus s&h.
> New tubular lower control arms (pair), 3" drop, poly-bushings & bump stops installed. $225 plus s&h.
> Heater controls for '98- up S trucks w/out A/C, heated mirrors or rear defrost. I was going to use this when I deleted my a/c but I decided not to replace my original. Anyways, it's a little rough & I was mostly going to use it for the face. The back plug in is cracked, the knobs are a little dirty & in rough shape. This is pretty rare because almost all trucks have A/C in them. $9 plus $10 shipping.
> 7.5/7.625 drivers side backing plate for drum brake setup, should fit all chevy 10 bolt rears (8.5 included). $5 plus $12 shipping.
> Master cylinder & proportioning valve from a '92 Astro. $10 plus $10 shipping.
> Spreadbore to squarebore adapter. About 1.5" spacer. For four barrel carbs. $9 plus $10 shipping.
> Squarebore spacer. About 1.5" spacer. For four barrel carbs. $9 plus $10 shipping.
> 7.5/7.625 OEM rear end covers. $5 each plus $10 shipping.
> Auto Meter Pro-Comp fuel level gauge compatible w/ GM sending units. New in box! Summit currently sells them for $35.99 plus $9 shipping, that equals about $45. ..I just want $20 plus $10 shipping.
> Chrome alternator bracket for a SBC/4.3. $10 plus $10 shipping.
> OEM head units. I have two to choose from. One's an AM/FM & a tape player & the other is just plain old AM/FM. If you'd like a pigtail of wire off the stock connector I only have one left. $5 each plus $10 shipping.
> 600 CFM Carter carb w/ electric choke needs to be cleaned up from sitting in the garage. $20 plus s&h!
> 2 brl Rochester, elec. choke. needs a rebuild. $9 plus s&h.
> Triple gauge kit w/ chrome mounting bracket. Mechanical gauges. Coolant temp, Oil pressure & an Ammeter. $12 plus $10 shipping.
> 11/32 single groove valve locks part#601-16. These fit chevy small blocks & 4.3s among other engines. This is for one brand new set of 16. I have two sets. $8 plus $10 shipping.
> 8.5" open carrier w/ 3.08 gears. $20 plus s&h.
> Cast exhaust manifolds from a late 70's Camaro for S10 V8 conversion. No AIR injection fittings on these manifolds. I can clean & paint them black for an additional $10. $15 plus s&h or $25 plus s&h (cleaned & painted)
> OEM 700R4 torque convertor. Was behind a V8 not a V6. $9 plus s&h.
> Header reducers 3" to 2.5" slanted. Mostly used w/ center dump headers. $10 plus $10 s&h.
> Header reducers 3" to 2.25" straight, 3 bolt flange not included. $5 plus $10 s&h.
> Header reducers ball & socket style. 2.5" to 2". 3 bolt flange not included (requires 2.5" flange) $5 plus $10 s&h.
> GM 1962-1974 NOS Cap, rotor & capacitor All AC Delco & everything but rotor is in original pkgs $30 plus $10 s&h.
> Idler Pulley came from a later model 4.3/5.0/5.7, smooth face no grooves. $5 plus $10 s&h.
> 2 V belts to choose from. One is 34.5" & the other is 45.0". Each is $5 (or get both for $10) plus $10 s&h.
> Screw-in Rocker studs. 3/8" top 7/16" bottom. These are used. They were made by GM. $25 plus $10 s&h.
> 90s-00s Pontiac Grand Prix Shifter just the shifter & boot. $20 plus s&h.
> K&N Round Air filter. 9.5" diameter x 2.75" height. $10 plus $10 s&h.
> SBC header gaskets their seperated & manufactured to just slide in once the headers are in loosely. $10 plus $10 s&h.
> Motor mounts used but not used up. They look exactly like 2.8/SBC/corvette mounts. $15 plus s&h.
> Parts here for Pontiac V8 engines sized 301-455 '66-up. Edelbrock Performer intake $30, used alternator $5, remanfactured aluminum pump $15, remanufactured starter $15, NEW in box hi-performance harmonic balancer $40, NEW in box Hi-performance cam & lifter set (288/298 .444/.466). $90... plus s&h
> Datsun R200 open rear w/ half-shafts. It's a 3.90. $25 plus s&h!
> Datsun 240Z Grille. Great condition. $10 plus s&h.
> Datsun alternator. $5 plus s&h.
> Datsun vacuum brake booster. $10 plus s&h.
> Pontiac Catalina gauge cluster. 1976 & has a cracked face that can be replaced. $5 plus s&h.
> Finned rims. 4 lug 4x4.5 spacing.. they fit early chevy IIs & Datsuns among other vehicles. $50 plus s&h!!
I will consider best offers on all parts!
Need parts? I've problably got it.. http://www.s10planet.com/forum/showt...2425#post72425
1972 Datsun 240Z (AKA the car from www.Fastassdatsun.com.. site is now somewhat back in action)
2002 Chevy S10 Xtreme
Old 10-02-2007, 07:43 PM
Updated list w/ a few more goodies & a little less crap.
Old 10-11-2007, 02:50 PM
Holley 670cfm carb is sold
Old 10-20-2007, 07:02 PM
More parts added...
> Fuel Regulator Summit brand. Used to twice start the Datsun's engine. $20 plus $10 s&h.
> Idler Pulley came from a later model 4.3, smooth face no grooves. $5 plus $10 s&h.
> Fuel pump block off. Long since forgotten what it was for.. I have a picture. You decide. $5 plus $10 s&h.
Old 10-27-2007, 08:29 PM
Ok, here's the deal.. I want to see a lot of this stuff go. SOOOO.. I'm going to run a sale. From now until November 30th anything bought will have 20% taken off (taken off the base price not including shipping)! When I drop it 20% I'll round to the next dollar up so you save more... no penny savings! So c'mon everyone.. help a brotha' out!
Old 11-10-2007, 05:59 PM
Added
Old 11-22-2007, 12:36 PM
Added:
Old 11-28-2007, 08:59 AM
Sale has 3 days left!
Old 11-29-2007, 06:51 PM
Added:
Old 12-10-2007, 09:03 AM
Sold:
