Old 04-04-2020, 06:29 PM
Nice work on the exhaust. Are those made mufflers or bought? The welds make it look custom made.
Old 04-04-2020, 10:13 PM
WILWAXU WILWAXU is offline
Thumbs up
Up next week is exhaust. Because Holley make a kit now hopefully it will go quick. But like everything on these car I wanted to modify the “off the shelf” system.
Holley did some one off mufflers to knock down the sound pressure.
https://lateral-g.net/forums/showpos...&postcount=268
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
The Following User Says Thank You to WILWAXU For This Useful Post:
WSSix (04-06-2020)
  #293
Old 04-05-2020, 06:43 AM
jmac jmac is offline
Thanks for the update!
Have more questions for you, I know, I'm that annoying kid in class that asks all the questions
What are the tabs/brackets circled below?
We know you and most everybody makes those trunk notches in order to route the exhaust up over the rear, but in this one pic, it looks like there's a section taken out from the rear seat area. What was that for?
As always, thanks for sharing and your time!
My 1967 Camaro
Old 04-05-2020, 09:18 AM
Stielow's Avatar
Stielow Stielow is offline
The holes in the top photo are pass throughs for the diff vent, fuel tank vent Two Much Canisters. Also a pass through for wiring.
The tab in the middle photo is the pickup point for a brace brace that reinforces the pan hard rod. I’ve added this to my last 4 build to stiffen up the DSE bracket.
The last photo is the clearance hole we cut into the floor pan for exhaust clearance. We will fill patch it once the exhaust is done. It gave us a ton of extra room for the 3 inch pipe to go over the axle.
Stielow Engineering
The Following 4 Users Say Thank You to Stielow For This Useful Post:
fleetus macmullitz (04-05-2020), jmac (04-06-2020), rat_rod_russell (10-16-2020), warhawkchevelle (04-05-2020)
  #295
Old 04-05-2020, 01:58 PM
67_camaroRS's Avatar
67_camaroRS 67_camaroRS is offline
Some random build photos.
Hey mark, what Master Cylinder, Brake Booster and proportioning system are you using on this car? Thanks
1967 Camaro RS
1969 Camaro coupe
Old 04-05-2020, 02:31 PM
Stielow's Avatar
The Detroit Speed booster and master. Prop valve Willwood off memory.
Stielow Engineering
Old 04-05-2020, 05:28 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
If you’re running ABS why are you using a prop valve? I’ve seen it on a few of your builds and with the C5 ABS I have for my car I know it controls bias. Is it just a back up fail safe you’re using it for?
Instagram- camaroaj
Old 04-05-2020, 05:32 PM
Stielow's Avatar
Yes I balance the system with ABS turned off then turn on the ABS. Yes it is an event of ABS system fault. Not likely but give me a piece of mind.
Stielow Engineering
The Following 3 Users Say Thank You to Stielow For This Useful Post:
pannetron (01-03-2021), rat_rod_russell (10-16-2020), vdrivinmike (04-05-2020)
  #299
Old 04-05-2020, 07:04 PM
CamaroAJ's Avatar
Good information. Does having the prop valve in it set to balance the car with the ABS off mess with the balance when the ABS is turned back on?
Instagram- camaroaj
Old 04-05-2020, 09:19 PM
Anyone want to bet Mark's brain is running overtime with this quarantine thing ... off work, isolation,... coming up with his next great part, mod, build ,trend
