Originally Posted by Roberts68
Let the teardown commence!
Are you making any mods to the sub? I picked one up awhile back that needs a little tlc To the right front, in front of the crossmember. It looks like somebody did some redneck towing around the woods or bumped into it when it was sitting for the last several years.
I was happy to find one that is solid and straight as far as suspension and body mounts are concerned.
Your list looked pretty thourough, but I would echo Vince somewhat on labor raising value but it is hard to justify. Also, I thought BG was back... even if someone bailed them out?
Well the subframe plan was to do arms, geometry, real shocks, and spindles but that money is probably gone with upgrades associated with the fire. Since the motor needs to come out for insurance work that creates an opportunity to install the heads, properly reseal the oil pan, new headers with good flanges and improved clearances would be an improvement. A mini-starter to replace the stocker........it never ends.
The sub I have is pushed inward slightly just to the rear of the upper control arm mount but those frames don't look to be too hard to tweak IMO. I've checked the width and triangulated spec measurements it doesn't appear to be more than .25" out but I haven't checked the vertical dimensions yet. Once I get torn down and cleaned up I'll get it straighted and weld up the seams for additional strength have it blasted and powdercoated.
I'll be working with the restoration shop on fairly capturing labor where-ever possible. Every dollar adds up even though the itemization takes a fair amount of time. Wire, terminals, and fasteners add up fast.
I believe BG was bought, I'm thinking I heard by Summit.
