Old 07-03-2008, 09:03 PM
skatinjay27's Avatar
the wheels looks awesomw with the car now jody!!!! they are a bad azz looking wheels the way they were, they just didnt flow with the car, i thought it was the wheel it self though and not just the color...boy did you prove me wrong!!! lol looks awesome man...
o the turbo woes... it will all be worth it in the end, maybe
AJ
Old 07-03-2008, 09:41 PM
Tom.A's Avatar
Tom.A Tom.A is offline
Looks great. I like the choice on changing color on the wheels also. Hope you get it worked out.
Originally Posted by cmraman View Post
It's not a Camaro steve. Don't you work or a Camaro Rag now?
I bet that he also does the Chevelle mag that comes out four times a year.
Tom
Old 07-04-2008, 05:59 AM
well, that's another issue. Even with the manual boost controller all the way in and the springs in the wastegates at 12 psi, it only shows 10 psi on the gauge. Runs pretty good for 10 psi, but should make way more than that.
I have gone out and flogged it a bit at that boost, and that didn't seem to help, in fact it was after that, that the car started smoking out the drivers pipe. I'll probably go out and beat the living crap out of it tomorrow, because if I gotta pull the engine I've got very little to lose............
Heck yeah flog it HARD! Sounds like your just running on the wastegate spring, crank that thing down tight and give her heck... I hope it's just a matter of seating that ring. I'm itching to see video of the beast in action.
Jeff Allen
J2 Speed and Custom
Old 07-04-2008, 06:17 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Said many times, but I'll say it again... AMAZING car, Jody.
My LS7 69 Camaro
Old 07-04-2008, 07:27 AM
Steve1968LS2's Avatar
Give that man a prize.. plus I shoot for Super Chevy. Only Fords and Mopars are outside my realm
Old 07-04-2008, 08:24 AM
NovaBlue71's Avatar
NovaBlue71 NovaBlue71 is offline
Car is looking great Jody . Hang in there I'm sure you'll get that turbo issue sorted out. Joe
Old 07-04-2008, 01:57 PM
camcojb camcojb is offline
thanks again. I pulled the plugs on that side of the engine, all spotless, no oil. Did a leakdown (cold) and all were 5-6%. Pulled the valve cover and all seals are intact and accounted for.
Not sure what it is, but I'm going to put some miles on it and see what happens. Only smokes at idle, and only after you stop for 15-20 seconds or so.
It also will only make 10 psi of boost. The wastegates are set at 13 psi (springs) so I'm confused on this one too.......... It has a manual boost controller that worked fine with the other motor. I've checked the lines several times as well as the controller (with compressed air) and everything looks fine. Even switched the lines around, but it made no difference. These are Tial 44mm units.
Drove the car into town, runs fine. Never got over 190 degrees, never missed a beat. Did find myself timing lights so I wouldn't have to stop for long though..................
Old 07-04-2008, 02:00 PM
badmatt's Avatar
badmatt badmatt is offline
in car video jody? hehe
looks awesome!
Old 07-04-2008, 02:19 PM
jannes_z-28's Avatar
Congrats on getting it running Jody!
Hope the oilsmoking isn't any major thing.
Looks awesome.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
Old 07-04-2008, 02:48 PM
CRCRFT78's Avatar
CRCRFT78 CRCRFT78 is offline
Looks good Jody! Hopefully you can shake those gremlins without having to tear it apart AGAIN.
