Old 04-27-2010, 06:56 AM
I ran my cables through the car. Between the tunnel and passenger seat.
Old 04-27-2010, 07:06 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
I just talked to Mark at Precision Shaft Technologies.
Based on the hp, PRM, and use of the car he is recommending a 3.5" steel shaft with the 1330 (FORD) rear joint that is good up to 700 hp.
You guys are right too. Without me telling him - he guessed exactly where it had broken and said it is a crictical speed issue. MAN...am I a believer now! While I have almost always had my shafts balanced, I haven't always upgraded them. I have had them shortened and lengthened before - but on "STREET" cars I hadn't sweated this before. On my Corvettes the shaft is more or less fixed as the diff is mounted solid and there is very little movement or issue. Also, they are substantially shorter. However, it could be cause there too to be aware of.
Aluminum would be cool - but just isn't needed.
Shaft will be here next week.
Okay...still mulling over the possible battery cable options. You can come up with a bad scenario for anything in terms of ways to short the cable or start a fire.
Did you guys know the new BMW's have pyro technology in their main battery cable? When the Airbag system senses a crash the main battery cable will blow a charge and kill the connection to the car. That prevents a live battery and cable from burning things down. It is a really cool concept until you have a BMW blow the cable...and you didn't know it had one...and you spend days and days and days trying to figure out why there is no power in the car!
Old 04-27-2010, 07:26 AM
I keep reading "cables" as in plural.... I would really hope that you guys are only running ONE cable - as in a positive - forward to either the starter motor or to a post/terminal somewhere up "front".
The whole car - body and chassis - is the ground... with a short ground strap from the batter to somewhere right close to where the battery is mounted.
I then run short ground straps - under the car from the block to the chassis - and another one from the body to the chassis.... so I have good grounds and I'm not relying on bolts and screws. Use a STAR WASHER under the ground - these are made to cut into the paint/primer to give you good metal to metal contact.
When I run cables or wiring thru the floor - I use a marine grade (west marine) bulkhead fitting. There are many types - and their use depends on what you're doing - where - etc. I like the water tight versions that you run the cable thru - and a nut threads on and clamps the cable and also makes it water tight.
BTW -- worrying about a fire in an accident is a bit overkill and over thinking. You don't drive this car daily - reducing your risk 100's fold - which is why your insurance is about 1/3 of your daily driver... yet the value of the Camaro is probably higher. Why? Because of the reduced exposure. Think about the millions of factory cars running around -- they don't or haven't - taken any particular action regarding battery started fires. Batteries are up front - in back - under seats - in trunks...
If you're really worried about that -- think about this - the two terminals are "exposed" -- what if you get in a wreck and the metal around the battery is crushed and shorts out the terminals....
I'm just saying - there's too many scenarios... Just put the battery where you want it and run your cables...
Old 04-27-2010, 04:30 PM
69MyWay's Avatar
By profession I am an auto insurance/collision research specialist. In other words, I spend a lot of time looking at crashed and burned vehicles from around the country. We search, research and try to determine defects that lead to fires, brake, steering...and yes...UNWANTED (can you say Toyota) acceleration failures.
Anyway - I see the worst of the worst and it tends to color my view of things.
As said - there is no perfect place to put the battery cable. Looking for the best of all possible bad places.
I got the loop today. It is a bolt up universal piece. It looks like it has a good area to go in but have to wait on the driveshaft. I do want to weld the two halves up when I'm satisfied. Ordered a new X pipe center section so we can rebuild the exhaust. Local shop doesn't want to build copies of the pieces that were damaged off the car.
Old 04-28-2010, 12:01 PM
69MyWay's Avatar
Check out the June 2010 PHR "Getting Shafted" on page 68. There is a good explanation of critical speed failures in there.
Old 05-04-2010, 07:59 AM
69MyWay's Avatar
New shaft came in last night. It is amazing how that extra 1/2" really looks more stout than the old one.
I didn't notice until last night the U bolts were also abused in the failure so I'm out to pick up a new set today at the 1330 joint at the diff yoke.
My loop is fairly tight to the shaft from side to side. I'll give it a good thrashing prior to the dyno and do a full review to make sure there is no paint transfer from the shaft to the loop from drivetrain shift. This is the downside to the bigger shaft and the tight tunnel in the 1st gen.
Hoping the trans is healthy still. If that is out...I'm out for the rest of the summer because I have no time to get involved in that for the next 90 days or so.
Old 05-04-2010, 08:14 AM
I ran my negative cable all the way to the Bellhousing. I also ran a ground strap from the bellhousing to the fireway. Can't think of a better ground than a bellhousing bolt. It's also 6 inches from the starter which is the biggest load in the system. When I researched it, the consensus was that running the cable was the best route. I'd rather ground through a 0-2 gauge high quality cable than 40 year old sheet metal and frame. More than one way to skin a cat.
Old 05-04-2010, 08:20 AM
No question or argument from me.... I just run a big cable from the block to the chassis - and another short run from the body to the chassis... when you stack up the dimension of the body - and the frame -- it's way bigger that 0-2.
I don't rely on the body mount points - or the bolts and tranny connection points to carry a ground... They're grounded securely with cable. We're doing the same thing - minus the long ground cable... so its SSDD..
The KEY is that there are great grounds! People seem to discount the ground side of a circuit... somehow that word (Circuit) eludes them...
Old 05-04-2010, 08:32 AM
The frame and sheet metal on Camaros are a little thinner than that hunk of iron in your garage. I still like my main ground right near the starter and fuse box. One body ground and it's done. After all, GM configured it through a block ground. The only major current draw in the rear is the fuel pump. I put the relay back there and grounded it directly to the battery. My way is better than yours....
Old 05-04-2010, 09:11 AM
I yield to the gambler...
I've got 1200 WATTS of big azz stereo amps under the back seat -- thus added a big azz ground back there... so have TWO big un's and everyone knows that two is better than one!
We're talking CARS here -- BIGGER is always Mo' betta... Well... until you learn a few things that is.
