Old 08-11-2011, 12:15 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Default Chad's 68 Camaro V3.0 build. LS3 & TCI goodies
Been trying to make my way over to this site more often so I figured I'd throw up my build here too.
Version 1.0 of my 68 Camaro was a great car. In fact between V1.0 and 3.0 your average person looking at the car won't notice a huge difference. On the street there won't be a huge difference. However, like many on this site I can't leave well enough alone and after owning the car for 5 years I'm doing an even bigger upgrade than V2.0 was.
V1.0 had the equivalent of a Hotchkis TVS kit with 16 TTII wheels, EFI, 6 speed and was a great street car. Here is a pic.
However, after attending my first track day in 2009 I wanted MORE. So Version 2.0 consisted of ATS AFX spindles, SPC upper and lower control arms, C6 Z51 front brakes, 18" wheels with better rubber and eventually an adjustable rear bar to give me better handling. I did a post on that round of upgrades over on PT.com
Here is one of my favorite shots V2.0 in action:
So
After getting more and more into track days I've embarked on Version 3.0 of my car. Current planned upgrades are:
MORE POWA!!! In the form of:
- Mast Motorsports LS3 427. Have already picked this up off of craigslist, never installed.
Better Handling!!!! In the form of:
- TCI engineering front subframe with double adjustable coil overs and 13" 6 piston willwoods.
- TCI engineering rear torque arm with double adjustable coil overs and 13" 4 piston willwoods.
At the same time I will be swapping out my 8.5" 10 bolt to a 12 bolt but keeping the 3.73 ratio and posi.
I really wanted to run more tire up front and already had some slight rubbing issues with my V2.0 set up. I've seen TCI kick but with their car at a variety of autocrosses and RTTC and appreciate the bang for the buck of that set up. And since I'm swapping out the rear and suspension now was the time if ever to mini tub. So that is what I'm doing. Target is to run 275 front tire and 315 rear tire on 18" rims. Because I also am upgrading to FIKSE Profil 5S wheels I did a 9.5" front and 11.5" rear rim to allow me to go 285 up front evenutally and switch between 315 and 335 out back.
I wasn't exactly suffering traction problems in the rear, rather I continued to suffer from too much understear for my tastes. However, with the addition of another 250 horsepower from the engine upgrade the mini tub seemed like a good idea.
I will hopefully be posting lots of pics as the build progresses.
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
