Old 05-16-2012, 09:52 PM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
Here are some updates for this week... I made the decision today to go LS on the test car.. It is the bulk of the work we do @ JCG...
Cris Gonzalez
Old 05-16-2012, 10:10 PM
Flash68's Avatar
Flash68 Flash68 is offline
BOOOOOOOOO!!! Rich and I are not happy about that.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
Chris, you guys do great work and come up with some trick pieces.
One observation was on your subframe and rear clip the seams on the steel are in random places, not all to the inside or outside. If someone were to buy one of your subframes and just wanted to paint and install the seams would be noticeable. Alot of grinding and bodywork would be needed to hide the seams. I would just put all of the seams to the inside, may cost you a little more tubing but in the end I think look better. Just my .02
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 05-18-2012, 08:39 AM
Cris@JCG's Avatar
Yeah! But guys need to get out of the stone ages! While your @ it .. bring Todd in from the dark side!
That was a detail that got by on me with a few others.. but this is not a car that will have alot of detail.. It is my test car.. The front sub has been a pain to fabricate... We are looking at ways to optimize for the others I need to build...
Cris Gonzalez
Old 07-03-2012, 08:38 PM
Cris@JCG's Avatar
Well my first prototype sub-frame has been a challenge… This why we build prototypes so that we can catch the things that will work & need to be modified..
The first thing that was a issue was the steering column that did not have the clearance we needed.. then the frame rails were too narrow to build headers.. then we needed to build engine mounts… then have clearance for accessory drive system…
So plan B.. We redesigned the frame rails to clear all the problems that we were having… It will use 2010 Camaro accessory drive, more friendly for clearances on the steering shaft & headers, & plus it will be fabricated frame rails for optimization of building the frame rails… In the mean time we have modified the first chassis so it can still be used for test purposes & the we finally built the control arms.. We will have Rev 2 of the chassis in a few weeks..
Cris Gonzalez
Old 07-04-2012, 09:13 AM
Jr's Avatar
Jr Jr is offline
Your pictures look great. What size is that front tire?
Old 07-04-2012, 10:58 AM
cencalc6 cencalc6 is offline
Looking really nice Chris
Old 07-04-2012, 11:33 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Nice updates. Looking really good.
Old 07-05-2012, 07:00 PM
Cris@JCG's Avatar
305-30-19 .. I think I can make it work.. if not a 295-35-18 will just be fine..
Thank you!
Cris Gonzalez
Old 07-10-2012, 10:10 AM
Cris@JCG's Avatar
We got around to mounting some front sheetmetal to confirm that all measuremnts were good.. plus check the ride height & center wheel well opening on center of fender... The front tire is a 295-35-18 on 18x10.. Just need to modify the inner well torwards the fender mount for clearance.. We automatically built -1 camber into the lower control arm.. Currently running -3 camber & 5 deg on caster..
Cris Gonzalez
