Old 01-09-2015, 06:01 PM
Rod P's Avatar
Rod P Rod P is offline
Originally Posted by Che70velle View Post
Rod, your saying your running GM axles? What rear brake package are you running? Do you experience significant pad knock back?
never had that as an issue, knock back means the axles are moving, a good rearend shop will shim the axles to reduce movement when they shim the Tru-Trac
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
