View Poll Results: What's your trans
TKO-600 42 45.16%
TKO-500 1 1.08%
T56 42 45.16%
4 Speed 8 8.60%
Voters: 93. You may not vote on this poll
Old 03-16-2007, 09:42 AM
67camaro327's Avatar
67camaro327 67camaro327 is offline
Originally Posted by nitrorocket
First, it depends on the year and model of vehicle the T56 came out of. Any of the 98+ t56 trans will be stronger then all the overdrive transmissions listed, especially if you upgrade the output shaft.
Second, the only thing that breaks from to much power is the output shaft. The 3 rd gear and 5 gear will be a time bomb at the 1000 rwhp level.
What broke on the trans you know of?
oh i woulda thought the tremec would hold more power than a stock t56. Im not exactly sure, a lot of people on my local f body board have had problems with theres, ill have to see what eactly breaks.
www.fquick.com/67camaro327
Old 03-16-2007, 09:54 AM
nitrorocket's Avatar
I am sure you will find the typical damged items with a search for a t56. 3-4 broken or bent shift fork, stamped keys bending, and plastic shift pads breaking and falling ff the fork.
An uograded shift fork is about $90, billet keys are about $70, and the bronze shift pads are about $90.
They solve all the problems from abusive shifting. As far as breaking anything will in a gear, that just doesn't happen excpet for what I mentioned in my last post.
Twin Turbo LS1 '71 Chevelle
1000 hp 93 octane street car
6 speed
