Old 02-27-2018, 06:42 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Thanks,you great do super nice work
Old 02-27-2018, 06:43 PM
V8TV's Avatar
V8TV V8TV is offline
Thanks for the compliment, I'll share it with the crew!
Kevin Oeste
V8 Speed and Resto Shop
V8TV
Muscle Car Of The Week
V8 Radio Podcast
All about us:
https://www.v8speedshop.com
Old 03-16-2018, 04:11 PM
V8TV's Avatar
Meanwhile, the crew did some bodywork on the custom firewall and prepped it for paint. A gray coat of epoxy provides corrosion protection.
It didn’t need much, but we skim-coated the panel with Evercoat Ultra filler and blocked it flat as can be.
After filler, the panel was sprayed with a polyester filler, and block sanded some more.
The polyester is blocked until flat, removing any sanding scratches or marks left from the previous steps. It is sanded to 220 grit, and then brought back to the booth for some 2k high-build primer and more block sanding.
The seams were also sealed to prevent corrosion.
After the primer was sanded to 600 grit, Jeff sprays a satin black urethane on the firewall.
[img]https://lh3.googleusercontent.com/-oQEe9X7k0FQ/Wqwvxjye4FI/AAAAAAAC4x8/9aUOZkJLHDk5f2ZhKqnuVm2PN3Bcq1izgCHMYBhgL/s1600/1969%2BCamaro%2BLA_2018-03-12.0006.JPG/[img]
Once the paint dried, the satin finish was revealed.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
The Following 3 Users Say Thank You to V8TV For This Useful Post:
gofastwclass (03-16-2018), Mikael A (03-17-2018), NAPA 68 (03-16-2018)
  #34
Old 03-28-2018, 02:28 PM
V8TV's Avatar
Once the firewall was cured, the mechanic shop took over with the final install of all the goodies.
The Detroit Speed subframe and suspension was cleaned up amd the new firewall protected as the LT4 was set in place.
Looking pretty good up there.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 04-17-2018, 02:33 PM
V8TV's Avatar
The team begins to install the various systems on the car and LT4.
Engine wiring is routed low through the bulkhead plate made in our metal shop.
The Ultimate Headers are exhaust artwork, with cast stainless flanges and stainless tubes. The ARP hardware squeezes MLS gaskets, and the headers utilize 1 ⅞” stainless tubes. These are Jet-Hot coated satin black.
Detroit Speed subframe leaves plenty of room for headers.
They sure are pretty.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 04-17-2018, 02:34 PM
V8TV's Avatar
Detroit Speed wiper motor provides a bit of room in addition to delay wiper action.
Battery lives in trunk out of the way.
Water pump is tapped for temp sensor.
Engine ECM lives on driver side of firewall inside of fender.
Engine power center will live on passenger side.
Radiator core support set back in place.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 04-17-2018, 02:36 PM
V8TV's Avatar
Superchargers create a lot of heat, so the cooling system needs to be effective. The LT4 will be keeping its cool thanks to a C&R Racing radiator and supercharger heat exchanger. These are bred from C&R’s F1 racing program and offer many innovations for performance and strength.
The heat exchanger is designed for the Camaro’s grille opening size.
Pins on the bottom of the heat exchanger locate it in the mount, which uses rubber bushings to protect against vibration harm.
Mounting “shelf” with rubber bushings.
A rubber padded top mount slips between the stock Camaro support and vertical bracing.
Note the 4 mounting tabs and screws, those are for mounting a Vintage Air condenser core to the front of the heat exchanger. These are provided by C&R.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 04-17-2018, 02:37 PM
V8TV's Avatar
On the back side, the radiator is mounted to the core support.
A high fin and tube per inch count increases surface area for better cooling, and the tubes are actually extruded for strength. These are shots of a cutaway:
C&R builds these tube cores to withstand pressure of 100 psi in F1 racing, a pressure they won’t ever see in a street car like this, but they withstand “ballooning” and potential cracking and bursting like rolled tubes.
They’ve also added reinforcements to the structure to keep the tanks and cores from separating and leaking.
The driver side incorporates an engine oil cooler, and the twin Spal fans are visible here.
Passenger side connections for engine coolant. Aluminum bracketry bolts to the stock Camaro radiator support locations.
Here, the Vintage Air A/C condenser core has been added to the front of the heat exchanger.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 04-17-2018, 08:17 PM
DOOM's Avatar
DOOM DOOM is offline
Kevin its lookin good!
Mario
USCOLLISION
Old 04-18-2018, 01:51 AM
Jimbo1367 Jimbo1367 is offline
WOW. Great work Kevin. The C & R stuff looks top notch.
