Old 02-01-2018, 04:02 PM
V8TV's Avatar
V8TV V8TV is offline
Default 1969 Camaro Transforms From Big Block to Supercharged LT4 V8 at V8 Speed & Resto Shop
This is the next chapter of the 1969 Camaro we modified in the V8 Speed & Resto Shop with all new Detroit Speed suspension, Forgeline Wheels, Baer Brakes, Toyo Tires, Holley EFI, and more go-fast and handling goodies. Here’s the original forum thread telling that part of the story:
LateralG: https://goo.gl/7DKBZj
And the video from that experience:
https://youtu.be/LlJ3yb0MqR8
Well, remember how we said that some cars are never finished, and are on a constant evolution to improve? WELL, this ‘69 is back in the shop for some upgrades once again!
This time, the owner wanted to change the personality of the car a bit and move from the angry 540 Big Block Chevy into an LT4 supercharged power plant for a more refined - but still powerful - driving experience.
We started the engine removal process by protecting the car with a Badass Fender Cover… which should be called a nose cone, to be honest.
We measured the spacing on the hood to fenders and valance for reference, and then removed the hood. All the engine fluids were drained, exhaust was disconnected, wiring harnesses disconnected… all the usual items required for engine removal. Out came the big Chevy engine.
Tyler experiences DejaVu on this car, recalling the first time the engine came out of the car before the big suspension overhaul!
Kevin Oeste
V8 Speed and Resto Shop
V8TV
Muscle Car Of The Week
V8 Radio Podcast
All about us:
https://www.v8speedshop.com
Old 02-01-2018, 04:03 PM
V8TV's Avatar
The Chevrolet Performance LT4 V8 engine arrived on a pallet from another shop, where it had been painted black and upfitted with an underdrive pulley system to generate more supercharger boost pressure. The dry sump oil system tank is also visible on the pallet in this shot.
These generate around 640 horsepower and 630 lb. ft. of torque, but the mods on this one will ensure more oomph than that.
The LT4 features direct-injection, and it comes in the Z06 Corvette in regular production trim.
Here the Drive Junky LT4 front accessory system is visible.
Dry sump oiling system tank
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 02-01-2018, 07:40 PM
SWEET! Plenty of belt wrap one those pulleys. Did you bigger on the top pully as well as the bottom? Bottom I think I read 9.20, what is the top?
Old 02-02-2018, 02:46 PM
V8TV's Avatar
I believe the upper pulley is stock... pretty darn small from the factory. I imagine a smaller pulley would also be harder to keep traction for the belt with such small surface contact.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 02-02-2018, 07:09 PM
gofastwclass gofastwclass is offline
Nice. I wondered how long that would take.
I build my own junk...
Old 02-04-2018, 08:25 AM
syborg tt's Avatar
Subscribed !!!!
Sent from my iPad using Tapatalk
marty-mj
Old 02-04-2018, 12:08 PM
V8TV's Avatar
Time for a quick test-fit of the LT4.
We had recently installed a new Centerforce DYAD clutch and flywheel on our 540 big block Chevy engine but we wanted to run a Centerforce DYAD clutch with the LT engine as well. However, the LT flywheel would be different. Rather than install the new flywheel with a used clutch and split up the set, we elected to obtain a new flywheel and DYAD DS clutch from Centerforce for the LT engine, and offer the matched clutch and flywheel from the big block for sale.
The Centerforce DYAD DS is a thing of mechanical beauty. The machined flywheel is nearly too nice to hide inside a bellhousing!
BUT… it wouldn’t do much good on the bench! ARP hardware holds it to the LT4 crank.
You’ll notice some pink / red dots on the components… these are alignment markings provided by Centerforce. This system was balanced at the factory, and they are kind enough to place the parts in the box all ready to go. However, if you seperate them, you can realign the parts using the dots to during installation so they remain in balance.
The DYAD part… the 11” clutch disc and the “floater” dual disc assembly. Centerforce claims these will hang on to up to 1300 lb. ft. of torque while still being able to drive comfortably. We’ve found the driveablility claim to be true in several high-hp cars, including this one with the 540. These units provide predictable “grab” with smooth engagement and a pedal you can live with.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 02-04-2018, 12:15 PM
V8TV's Avatar
The pressure plate and clutch plates mounted to the LT4 with ARP studs. The alignment tool is still in place in this shot. The pink dots correspond with the dot on the flywheel. The cad-plated ring is the front half of the explosion-proof scattershield.
Hydraulic throw-out bearing on the input shaft of the T56 Magnum 6-speed transmission.
The SFI spec bellhousing attached to the front of the transmission.
We lowered the LT4 into the nose of the Camaro and shot a quick video. Excuse the quality, this is from a V8TV “Minute To Winnit Live” video we streamed on our Facebook page.
Pics of the fit and some new surprises next time!
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
Old 02-05-2018, 06:26 AM
Jr's Avatar
Jr Jr is offline
Beautiful car.
What are your plans for the heat exchanger?
Old 02-05-2018, 07:42 AM
V8TV's Avatar
Originally Posted by Jr View Post
Beautiful car.
We'll be using a C&R unit designed to work with the LT4 and Vintage Air.
Kevin Oeste
V8TV
V8 Radio Podcast
All about us:
