Old 01-29-2013, 04:43 PM
Sonar Chief's Avatar
Post
Originally Posted by BBC71Nova View Post
Looking good.
I too am interested in those clamps. I'll have to google around for them I guess.
Also, which epoxy are you spraying?
I googled for images and came to Jeff Lilly Restoration, seems they also use the same clamps, so I emailed them to see if they knew where to get them. I'll post if they reply with useful info.
I put a link up in the paint/ body thread to their website.
The epoxy? Finish 1 FP301 made by Martin Senour and sold at your local Napa.
Originally Posted by KPC67 View Post
ANOTHER 0? I can't do the math
oh its easy to figure out.
Adding 0 would still equal 75 time that your quarters will go off and on.
Got it
Old 02-16-2013, 05:52 PM
Smile 2/16 Update
Some progress today started fitting everything to the firewall / cowl to get this thing welded .... not something to take lightly when the cowl, side cowls and the upper dash are new to the car. Paranoid? Maybe.
So I welded the driver's side bracket that holds the dash to the hinge pillar and the support I cut outa the middle (by the speaker bracket) and used clamps to hold everything. installed the brake booster, steering column, E brake and bolted the old upper dash to the dash and I have a larger gap on the driver's side dash to pillar then the passenger side .... hmmm. I even installed the kick panels to check the gap ... OCD?
That bracket gets welded to my new patch I made ... and the dash has to move towards the driver's side. Take it all apart and shorten that bracket some to let the dash come over .... that's for tomorrow thou.
Does anyone recognize this?
Getting all together!
Will have to modify this a little.
I have been busy with Stats 512 and homework and today was good to get out and work on the car ..... even if I have OCD .... I'll get her tomorrow
Thanks for looking ..
Old 02-17-2013, 03:53 PM
Smile Finally pulled the trigger!
The welder trigger that is .... took everything back apart and took that bracket off and put everything back together (w/ old dash top for reference) and got the gap equal on both sides ... probably better than GM did Measured a gazillions times again and got some heat on the top cowl and then took my time to get the firewall attached to the cowl, did not warp anything ... and that's a good day.
Anyway, here are some pics, I'll finish dressing the welds another day ... have some homework to do now!!
Put some heat here and did some massaginh w/ BFH.
NO MORE CLAMPS
Still straight, I'll finish the welds another day
I still have to do the side cowls, piece of cake now that I have a good reference for them that's not going to move.
Thanks for looking ...
Old 02-17-2013, 04:11 PM
coolwelder62's Avatar
Lookin real good.This 1st.gen will end up way better the second time around.GM never went to this kind of work in the fist place.
Old 02-17-2013, 04:27 PM
makoshark makoshark is offline
Got it looking good there Chief. Nice looking welds!
Old 02-17-2013, 07:03 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
very nice work,good looking welds
Old 02-17-2013, 07:48 PM
Roberts68 Roberts68 is offline
What Scott said! Way to go!
Old 02-18-2013, 02:54 PM
Smile Thanks guys
it was gratifying to see that cowl welded in place. No more clamps Your project is awesome by the way
welding that cowl was a milestone ... can't' go back now! Wish I could help you with front fitment ... but I'm not there yet!
I keep plugging away a little at a time.
thanks for commenting, that means a lot
There is more to come ........
Old 02-18-2013, 04:09 PM
Something is off on my car and I can't figure out exactly what it is. Fitting fenders, doors and hood shouldn't be this difficult, but it is on my car. I'm thinking, right now, that I may have to break the quarter loose in the door jamb area and see if there isn't some adjustment there. When I installed these NOS quarters, I got them to fit as tight as they could to the inner structure and to the doors.
Old 03-03-2013, 03:54 PM
Post
And that is why I don't want to touch my quarters
I'm working with my AMD rep here in town cuz my door skins don't fit over my frames with out persuasion .... Not sure where this will lead.
