Old 01-30-2015, 11:29 AM
Vince@Meanstreets's Avatar
Thus the foot pedal... for controlling your amperage. Your eyes are the monitor...
I usually crank the amps up to max for the tungsten then modulate with my foot. Too many numbers in my head as it is. Only time I really pay mind to the amps is when I know im going to be welding for more than an hour at a time then i'll set it so I can full floor the pedal and concentrate on the puddle.
Also I use a fixed #12 lens when I tig. No flash and blind. My eyes are much happier now.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 01-30-2015, 12:39 PM
Sieg's Avatar
Sieg Sieg is offline
Number 12 lens!
Do you paint your TIG rod white with a red tip?
Old 02-10-2015, 10:40 PM
redss86 redss86 is offline
Just now seen this thread, and read the entire thing. Tons of great info, and links. Lots of very nice welding also.
Cyclone ---
I've read your post about 5 times and have yet to comprehend what you're saying. My initial thought was that you're telling someone they should add up the thickness (gauge/dimension) of both pieces you're trying to well and then set your machine accordingly. I.E., a butt weld joint - of two .125" square tubes - should be welded at 250 amps.
Dude! Couldn't be further from correct.... So I don't know what your post is trying to say because I must have missed something there.
I believe what he means; is that when you place two square tubes side by side, the corners are thicker than the flats. Where as, if you but the tubes together end to end, then the thickness would be as listed.
Hang in there -- watch some videos -- this is a skill set that needs to be learned and it doesn't come easy or cheap. Once you get the hang of it - you can sell the MIG because it'll just sit in the corner.
Could not agree more! I have a Miller Syncrowave 250, a Millermatic 200, and a 110v Lincoln mig (don't remember model, it's at my brother's house). 9 times out of 10 I will TIG before I MIG. I know both of my Millers are older, but I bought the TIG over 12 yrs ago, and got a steal on the Millermatic. I will post some pics of some of my welds tomorrow (not on computer now.
Old 02-11-2015, 12:14 AM
Number 12 lens!
I've had to buy helmets that go down to 8 so I can see.... LOL
Old 02-11-2015, 08:19 AM
Ketzer's Avatar
Ketzer Ketzer is offline
^^ This! ^^
Old 02-12-2015, 09:35 PM
Solid LT1 Solid LT1 is offline
Has anyone been having issues with China sourced tungstens for their TIG? I bought some stuff off Amazon supposed to be 2% Lanthenated but it's fracturing and splitting on AC......my Thoriated stuff (DC) is old Linde stock works like a champ! I'm using a dedicated diamond wheel to sharpen the stuff. Gas system is fine, water cooler is fine. Please tell me brands your using with good quality.
Old 02-12-2015, 10:13 PM
I have found that when you are taking time to create and prep a work piece that trying to save a buck on un known quality consumables cost you alot more money in the long run.
My local place carries CK products and have been very happy with them.
Dealer for
NEVER FORGET -11
Old 02-12-2015, 10:46 PM
Since im here I want to share an experience I had today while doing some aluminum work. I was welding along, and about 3 mins or so into the bead the filler would start collecting onto the tungsten. Getting sucked up is all I can describe it. Its also strange that this did not happen when I was doing my practice runs. About 30 mins on scrap. Note that this has never happened to me without accidentaly getting the tung in the puddle.
Turned down the gas, adjusting it for more cleaning helped but as soon as things heated up i would start up.
Check out the picture, you can see the blow back spots.
So im going back and forth and I noticed that if I wiped my rod down with
acetone it would stop doing it for a longer period.
While texting I inedvertenly swapped my welding gloves and the problem never came back. Turn out when I was fitting the weld bung for the filler cap lubricant from the o-ring saturated the index finger on my glove. As the rod got hot and my finger got closer to the puddle it would release more contaminants. Bam blow back.
Moral of the story keep your gloves, equip and rod clean when going ball deep.
Dealer for
NEVER FORGET -11
Old 02-12-2015, 11:26 PM
rpm56's Avatar
rpm56 rpm56 is offline
That is a great reminder Vince. Everything has to be clean with tig
Bob
Build Thread- http://1969stang.com/forum/index.php...bitch-is-back/
There are 2 kinds of people, those who own pickups and those who borrow them.
Old 03-17-2015, 10:07 AM
Made some welds on my frame last night. First time welding in about 6 months. Used 1/16 ceriated with 1/16 er70s6, 140 amps max. First to were ok, last two look good to me. Let me hear your thoughts.
Here is what I am welding in (the short brace in front of the xmember).
