Old 07-23-2014, 11:32 PM
byndbad914's Avatar
byndbad914 byndbad914 is offline
Originally Posted by Payton King View Post
Moving it back 3 inches to get the wheel base to 108, where it is supposed to be.
Moving the front clip up 2 inches so I can get my LCA's to a more level postion. I am wanting to travel my tire around 3 inches and Jake has it set up where I am already compressed 2 inches at ride height. If I try and travel it 3 inches where it sits now I have bump, camber issues, Etc. and it will be out of the designed range. He assumed that I was going to travel the front 1.25 inches. I told him before he started that I wanted the control arms level at my 4 inch ride height...
Ride height will still be 4 inches at the rockers, relocting the shocks with some trick adjusters from Ron Sutton.
I like the way you are thinking! I too set my LCAs parallel to ground because of the added benefit of being so easy to verify suspension settings at the track after messing with cross weight even on uneven ground as you just quick verify you are 90 degrees to the frame. There are some that like them to angle "down" just a little bit from the inner point to the spindle point for camber gain but I have always found I can get a really good camber curve with level LCAs by just being careful about the UCA's inner mount points to get a correct length and pitch while making sure the static roll center stays in a range I desire. I am sure you will find a combo that does exactly what you want it to, just be prepared to reconsider the UCA mounting as well.
I don't always drink race gas, but when I do, it is dos equis.
Old 07-23-2014, 11:45 PM
Flash68's Avatar
Flash68 Flash68 is offline
I should have gone with my original plan of getting a Howe TA2 car.
Yawn. Fast... but yawn.
Forward buddy... forward!
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 07-24-2014, 08:08 AM
slenning's Avatar
slenning slenning is offline
This will be way cooler when done!! Sorry to hear about all the issues you're having.
Steve
70 Camaro - in process https://lateral-g.net/forums/showthread.php4?t=50636
69 Camaro LS7/T56 https://lateral-g.net/members/lenning/
69 Camaro SS396/350hp
64 Chevelle - patiently waiting
2014 Z28 Ashen Gray
2010 Camaro 2SS/RS Black w/White stripes (wife's car)
2015 SS (the 4 door one) Wife's other car
Old 07-24-2014, 10:01 AM
Payton King's Avatar
Hey Steve,
Figured you would be at Motor State. What is up with that?
Old 09-06-2014, 01:37 PM
Sieg's Avatar
Sieg Sieg is offline
Moon Walker is making major progress! :thumbups:
Old 09-08-2014, 08:15 AM
Ok that did make me laugh out loud.
Old 09-15-2014, 07:04 PM
grendel grendel is offline
Holy ****.
I am talking to Jake about doing my 73 Camaro.
Old 09-15-2014, 07:31 PM
Originally Posted by grendel View Post
Holy ****.
DON'T YOU DO IT!!
Old 09-15-2014, 07:33 PM
Holy ****.
Oh yeah -- and just asking about your name --- have you ever shot one??
Old 09-15-2014, 07:38 PM
Yes.
Although the name pre-dates the caliber.
