Old 03-18-2013, 07:13 PM
rsgt's Avatar
rsgt rsgt is offline
That looks really good. Keep after it.
Randy
spoilersbyrandy
Old 03-20-2013, 08:34 PM
Sonar Chief's Avatar
Smile
Little at a time and then your are done!
Old 03-20-2013, 08:51 PM
Thumbs up Going topless
the car that is , now that the cowl is structurally sound it's' time to get that roof off and see what needs attention.
So... off came the roof, the front header had the most rust (POR15 TIME) and the rest is looking like it will make it fine with some epoxy primer. I was worried about the area under the pinch weld for the drip rail and it looks like I can save it . Couple hours and the DeWalt and she's looking mo better.
Critters made a house in here!
Break out the Blair spot weld cutter!
The front header had the most rust!
Got the lead outa this side.
Cleaned up pretty good
I still have to get that drip rail part of the roof off ... that will take some delicate grinding, that's all for tonight.
Thanks for looking ....
Old 03-20-2013, 10:20 PM
Nice job you'd never know it was rusted.
Old 03-21-2013, 07:41 AM
Thumbs up Rusted
That is exactly right .... but knowing the history of the car and seeing the rust everywhere else I knew the roof had to come off the car.
Gotta do it right .... steady the course
Old 03-22-2013, 11:14 PM
Thumbs up Garage time!
It's snowing outside and cold but I figured I'd better get something done cuz spring break is over and it's back to school Monday. I got the roof separated from the driver's quarter and then I drilled out the spot welds across the back glass area ... it wasn't as bad as the front
Got this all ready for epoxy!
I'm tried of drilling out spot welds .... just surface rust.
Cleaned up nice .... wish I could spray epoxy this weekend.
I will work on the other side this weekend and get all ready for some epoxy when the weather permits ...
Thanks for looking .... it's late, more tomorrow!
Old 03-23-2013, 12:15 AM
makoshark makoshark is offline
Drilling out all those spot welds can kick your butt. That is one thing I am glad is over with on my build.
Old 03-23-2013, 08:21 AM
Smile
It kicked my butt last night .... but I told myself I was gonna finish this part tonight. So I fired up the heater and kept at it til it was done - it was 2300 when I got inside
Looks like there is 5 inches of snow outside now and it's still snowing .... oh well. I'll be in the garage here in a short.
Old 03-23-2013, 03:01 PM
Roberts68 Roberts68 is offline
Chief, are you still using primarily the red or tan scothbrite type roloc discs to remove surface rust?
What sort of RPM are you using in order to not smoke through the discs like no tomorrow?
Great work ethic!
Robert
Old 03-23-2013, 05:59 PM
Smile
Great work ethic!
Robert
I am using the fiber discs on my DeWalt to get all the surface rust down to metal, definitely lasts longer than the rolocs.
Just came in for dinner ... the passenger side drip rail/ roof piece is off, what a PITA!
I will post pictures later ... need to get some heat going (8 inches of snow and maybe 28F outside, maybe 50 inside the garage) and get the drivers side done, set goals and stick to them
