Old 05-18-2015, 03:53 AM
jarhead's Avatar
jarhead jarhead is offline
Very nice Aaron!
Which side was machined first, bottom? or Top?
Joe
joe
Semper Fi
My 68 Torino
Old 05-18-2015, 09:34 AM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
Originally Posted by bdahlg68 View Post
Sweet!
Beautiful!
Originally Posted by jarhead View Post
Very nice Aaron!
Joe
Thank you.
Joe, I did the inside first. This way, I was able to use a standard vise to clamp on the outside of the stock. I tapped the perimeter holes to #10-32 threads. Then for the second side, I took some scrap pieces and machined in the bolt pattern and then used bolts to hold it down. The bolts were just under the finished flange after it was fully machined. Eventually, I will clearance drill out the threads as the clamp ring (not made yet) has the threads in it. I have a set of ARP stainless bolts to finish it out.
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 05-18-2015, 01:40 PM
DavidBoren DavidBoren is offline
Too cool. You and your trick billet bits.
Old 05-18-2015, 04:00 PM
jarhead's Avatar
joe
Semper Fi
My 68 Torino
Old 07-09-2015, 04:05 PM
rat_rod_russell's Avatar
rat_rod_russell rat_rod_russell is offline
http://www.race-dezert.com/forum/thr...-truck.119258/
Not as good as the other race dezert build thread but its still got some amazing photos. I picked up a few jigging ideas for my frames like this one.
-Russell
PT-57
1957 Chevy Truck, 6.0L LS, T56, STS Twin Turbos, C6 Corvette Suspension, CAD Designed Frame by Hot Rod Jim's.
https://lateral-g.net/forums/showthread.php4?t=20292
http://www.nerdrods.com
Old 07-09-2015, 06:44 PM
David Pozzi's Avatar
Originally Posted by DBasher View Post
Very cool Rodger, thanks for sharing! 3G's just by lifting off the throttle...Holy Sh!t! Think about that!
I was on the salt when they broke the last record with Thrust SSC. Reports and pictures were rolling in from Black Rock and everyone was buzzing....pretty cool to be a part of! Let's see if they can keep this one on the ground!
Check out the pressure wave in front of Thrust....
This was taken a day or two before Andy Green set the record. Taken from one of two Ultralights they brought with them from the UK. I was lucky enough to buy a copy from the pilot and get Andy to autograph it.
Here's my page on it. The page is old and photos small because it was made for dial up downloading in those days. http://www.pozziracing.com/land_speedracing.htm
http://www.PozziRacing.com
