Old 10-19-2010, 08:42 AM
boonedog boonedog is offline
very nice work
Old 10-19-2010, 02:21 PM
pacificustoms's Avatar
pacificustoms pacificustoms is offline
Building a border to go around the engine compartment to fill in the dead space between the factory lip of the fender and the inner fender that we're building.
Here's a panel we built as a fender filler piece to go between the firewall and fender lip. The dimpled holes and mesh are just dress up pieces and have a backing plate to keep water and debris out of the door jam.
Robbie Azevedo
Pacific Coast Customs
Become a fan on facebook for weekly updates and giveaways: http://www.facebook.com/pacificcoastcustoms
Old 10-20-2010, 11:21 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Awesome work Robbie!
Old 10-20-2010, 11:48 AM
1Bad68Cat 1Bad68Cat is offline
Originally Posted by pacificustoms View Post
Gas tank built from scratch with all of the evap stuff from the original tank. We decided to keep everything GM put in the car, that way it's as close to "stock" as possible. We even re-used all of the plastic lines by heating them slightly, bending them and letting them rest in their new form. If you have a lot of patients, it isn't that difficult to do.
Do you sell the fuel pump module mouting hardware? I plan to build the tank for my 66 c10 and would like to use the factory fuel pump that came with the ly6/6l80 I picked up. Also, what do the connections on the fuel pump module go to? I assume the large line is fuel feed, medium is tank vent, and the small is the EVAP.
Thanks,
Robert
Old 10-20-2010, 02:13 PM
Any machine shop should be able to make you some. We machined them up ourselves for it. With your fuel pump we could machine some for you. I'm pretty sure the big one was the feed and both others went to evap. We just kept all the plastic lines and re-bent them around to all of the factory evap equipment. They do make adapters to clip onto those lines at the fuel pump and adapt to male AN fitting as well.
Robbie Azevedo
Old 10-20-2010, 02:26 PM
Sent you a pm. Buy the way, great work on the fabrication.
Robert
Old 10-20-2010, 03:16 PM
Thanks!
We fabricated a piece to go across the front to cover up all the ugly in the front of these things.
Machined our own hardware to hold it down. We wanted something really streamline as there isn't much hood clearance in the area.
Made matching pieces for the hood adjusters
Robbie Azevedo
Old 10-20-2010, 03:36 PM
War's Avatar
War War is offline
That's very nice clean work.
Jason
Old 10-20-2010, 04:07 PM
coolwelder62's Avatar
WOW!!! Robbie,Awesome fab work,over the top engineering. Scott
Old 10-21-2010, 02:39 PM
conekiller13's Avatar
conekiller13 conekiller13 is offline
Very high quality stuff there.....those welds are making wish I had 100th that skill.....
Dan
