Old 09-28-2011, 12:09 AM
DIGI-TAILS DIGI-TAILS is offline
nice progress!!! good luck!!!
http://www.digi-tails.com/
Old 09-28-2011, 02:44 AM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Awesome built, really like how you smoothed the firewall
Is it the 16 or 20 gauge sheet metal that you used for the firewall? Also do you have a photo of the firewall before installing the sheet metal on the firewall?
72 Camaro RS:SOLD
68 Camaro:
LS6 Engine,Tremec TKO 600,5 Speed
Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors, FIKSE FM5s
Old 09-28-2011, 09:46 AM
Your making some nice progress. The color looks great and I love those wheels.
Old 09-28-2011, 11:22 AM
CAMAROBOY69 CAMAROBOY69 is offline
Your Camaro is coming along real nice and its exciting to hear your updates. We are also going to be running the Vintage racing wheels so its nice to get an idea of what they look like actually bolted onto a car.
Adam_______Offical Car Name "ILLUSION"
383 Stroker, Stock cast heads, T-56 tranny, 4.11 gears, 2002 T/A dash, 4th gen interior including seatbelts, power lumbar seats, 18" Budnik Wheels,Hydratech Hydraboost
ILLUSION Website
--------------My Car on Lateral-g.net----------- Need something designed?-AdFabDesign
Old 01-05-2012, 06:16 PM
almcbri's Avatar
almcbri almcbri is offline
I got the fuel line and brake lines ran. I am going to have to modify the fuel line for my LS1 Fuel pump filter/regulator and for the flex hose running to the motor.
Tonight I dropped the car on all four wheels. I purchased Moog coil springs and will probably take an additional 1/4 or 1/2 coil off when its all said and done, but they might settle a little more. These are the springs that David Pozzi recommends on his site. I still need to finish plumbing the rear flex lines and getting the front disc brakes on. I have the under dash going where it needs to go and installed the gauges last weekend. Those Vhx gauges are awesome. The LS1 wiring has still got me lost and I hope to find someone local who has done the swap to help me get on the right track and make sure that I am doing everything right. Wiring has been a little challenging but the American Autowire Kit is really a nice kit and comes with some nice diagrams.
Old 01-05-2012, 07:23 PM
KPC67's Avatar
KPC67 KPC67 is offline
Great job, I missed the last couple of updates. You have made some very nice progress
Kevin Carter
Old 01-22-2012, 06:01 PM
almcbri's Avatar
I cut up a th400 x member and added some plate metal on the bottom. With the trans mount and the factory locations it's right at 4-5 degrees.
I have to take it to my dads shop to weld it up. My little mig is only good for tacking.
I used the car shop motor mounts. I will have $20 in the x member when done. Took me about 3 hours this evening. Mainly because of my lack of tools!
Old 03-17-2012, 07:04 PM
almcbri's Avatar
Today, I installed the Ididit column, power steering box and hooked the steering linkage back up. Also, I added oil to the motor. The ididit column went in fairly easy. I had to loosen the dash bolts and do a little work to get the column brackets to line up. I am having some power steering lines built and hopefully will have the fuel lines finished up in the next few weeks. My wife and I had our first 7 weeks ago. He has been keeping me pretty busy lately.
Old 03-18-2012, 08:52 AM
Sonar Chief's Avatar
Default Congrats
Very nice progress I like the rims and that blue is awesome!!!!
Congrats on the new member
Old 03-18-2012, 09:16 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
That's a good looking kid right there. Congratulations.
Car's looking good to.
Curtis
