Old 01-31-2013, 10:40 AM
Flash68's Avatar
Flash68 Flash68 is offline
I am glad there is more than one FE project going on around here.
Keep pluggin away. Nice to see progress on one of the FE builds.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 02-01-2013, 02:30 AM
390 S code 390 S code is offline
Engine fitted with rocker covers and aircleaner .Not a lot of time today fitted up the tailshaft and had to modify the strut brace mounting on the firewall as the aircleaner was hitting .some new photos
Old 02-03-2013, 09:59 PM
Default Fuel tank
Have had a busy weekend .Spent Saturday with my son making a custom alloy fuel tank .Being a Sheetmetal fabricator he made it look easy using a Cad cutter , all the pieces were cut to size and then folded . Another 4hrs welding and fitting it up. Here are some photos of its last fit up before having the lid welded in place . It has a surge tank for the pump to sit in and baffles to stop fuel from leving the pickup . He has also built in a baffle to stop fuel sloshing back up the filler under acceleration . Sunday was spent fitting the driver side extractors what a job .They are all seperate pipes but not a lot of room with a FE in a mustang engine bay i mean tight .
Old 02-07-2013, 11:36 AM
syborg tt's Avatar
Very cool car. I really like silver mustangs
marty-mj
Old 04-02-2013, 04:43 AM
It has been a while since i last posted as i have been waiting on parts to arrive from the USA . The dual pass Afco radiator has arrived which we are fitting up with a Ford taurus thermo fan the highest cfm fan available .My son is making a new alloy shroud and mounting brackets.I have fitted up the aircon condensor which came from a late model falcon which is a perfect fit with the radiator .Found a small alloy oil cooler at the wreckers for the power steering as the extractors run very close to the steering box will post some photos soon . Hope to have the new exhaust fitted next week ,then it is running all the electricals and fuel lines .Getting closer to firing it up
Old 04-05-2013, 05:35 AM
Default New photos
All the pulleys are now fitted with 120 amp alternator to run all the electronics. Steering wheel i am really impressed with looks a treat fitted in the car. The Afco radiator just fits between the rails will make a new aluminium shroud and will remove the fan from the plastic taurus shroud and fit it up these fans are said to be a good piece i am told it will have its work cutout in a hot queensland summer .The condensor is full width of the radiator and i have fitted a small oil cooler for the power steering .
Old 04-05-2013, 05:37 AM
Default Photos
a few more
Old 05-03-2013, 05:36 AM
Made some more progress with 3'' stainless exhaust and finished off the fuel lines .
Old 05-03-2013, 09:28 AM
fleet's Avatar
fleet fleet is offline
Originally Posted by FETorino View Post
Of course I love the car but I'm an FE Ford guy. Of course I don't know how anybody couldn't like the early Mustangs.
Especially this one.
Well done.
Old 05-10-2013, 12:37 AM
Making more progress today fitted up the remaining exhaust and fitted fan and alloy shroud to radiator.
