Old 02-27-2017, 02:33 PM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Great work! The metal work is extremely impressive.
Old 02-27-2017, 05:56 PM
66fury's Avatar
66fury 66fury is offline
wanted to know how the fiberglass to metal holds up over time.iv been doing bodywork for 30+yrs and when i was starting out ,i was always told to never do it use glass resin.i have bonded glass parts to metal using 3m bonding adhesive with great success in the past and not a combination of both.can you explain the process so i can understand?great work on the car!
mark
Old 03-11-2017, 11:04 AM
GPR's Avatar
GPR GPR is offline
This was the first time I have done this. I have worked on cars that had rust repair done in the past using fiberglass mat. One was over ten years old and was in a wreck and you could not tell that it had rust cut out and replaced with fiberglass mat until we started grinding on it. I have always done it like you have but after being in the sun all day I have seen a line where the end caps we bonded on my Mustang.
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 03-11-2017, 11:05 AM
GPR's Avatar
GPR GPR is offline
Quarter scoops were bolted and bonded with 3m8115 panel adhesive.
Major bodywork finished on the rear of the body yesterday
Today I sprayed two coats of SPI epoxy primer
Rusty Gillis
Port Richey Fl
Old 04-03-2017, 07:01 AM
GPR's Avatar
GPR GPR is offline
We had to add fiberglass to the side exhaust skirts to give us something to bond to the pinch weld.
Bonded to the rockers
Started the bodywork
Headlight bucket was bolted, bonded and fiberglassed to the fender
Front fender flares installed
Bodywork getting everything to line up
Ready for a couple coats of SPI epoxy primer
Rusty Gillis
Port Richey Fl
Old 04-03-2017, 05:13 PM
1badsc 1badsc is offline
lots of work but its looking real good
Old 04-03-2017, 05:57 PM
Mikael A Mikael A is offline
Looks great!!
Mike a
Old 04-04-2017, 12:39 AM
Dave Pratt's Avatar
Dave Pratt Dave Pratt is offline
That looks incredible...really great work.This thing is going to be killer
Old 06-27-2017, 11:01 AM
GPR's Avatar
GPR GPR is offline
Starting to fit the front apron
The shape was wrong under the headlight buckets so we cut it apart and glassed it back together
The spoiler was cut down and the front lip bonded back on.
After sanding
Bodywork to match the fender to the front apron
After a lot of sanding and priming
SPI black epoxy to seal the bodywork
Two coats of SPI Turbo primer
Rusty Gillis
Port Richey Fl
Old 09-20-2017, 02:13 PM
GPR's Avatar
GPR GPR is offline
Test fitting all the body panels
Rusty Gillis
Port Richey Fl
