Old 10-11-2015, 07:16 AM
syborg tt's Avatar
Just read this entire thread. Your teams attention to detail is fantastic. I am really looking forward to seeing this car completed.
Marty-mj
www.garagescene.net www.syborgtwinturbo.com www.2ndcamaro.com
marty-mj
Old 10-11-2015, 12:02 PM
GPR's Avatar
GPR GPR is offline
Brian wanted to see how 275 x 18's fit so he borrowed these from another project car
This is the owners original 255 x 17's that are now to narrow and will be going on my Mustang II restomod under construction.
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 10-23-2015, 10:02 AM
GPR's Avatar
GPR GPR is offline
Sprayed a little epoxy to keep it from getting any surface rust
Brian is starting on the other side. Bolted on the stone guard and front valance to keep everything lined up.
Left side
Welds ground
Rusty Gillis
Port Richey Fl
Old 11-02-2015, 10:17 AM
GPR's Avatar
GPR GPR is offline
Rod & Custom coilover rear suspension
Currie 9" with Wilwood brakes
Test fitting the rear suspension
Rusty Gillis
Port Richey Fl
Old 11-02-2015, 10:46 AM
GPR's Avatar
GPR GPR is offline
The original front fender flare has to be cut out
The fenders were sanded to bare metal and epoxy primed
We did a little bodywork on the inside of the fenders and epoxy primed
Rusty Gillis
Port Richey Fl
Old 11-02-2015, 02:58 PM
Got time to flare my Mustang like that? But might want to go even wider....
Old 11-03-2015, 05:45 AM
GPR's Avatar
GPR GPR is offline
We could do it but it would be about 6 months before we could get it in the shop.
Rusty Gillis
Port Richey Fl
Old 11-03-2015, 11:08 AM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
I'll "store" it for you until Rusty is ready for it my friend!
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 11-07-2015, 11:06 AM
GPR's Avatar
GPR GPR is offline
I have the second Rod & Custom rear suspension kit sold on my 1968 Coupe and it fit great. We can get the car real low if we want. The kit has been redesigned and it is a little harder to install and you cannot get it as low as my car.
The upper shock mount now has heim joints because I'm sure not all early Mustangs have the same distance between the frame rails. Tack welded in place
Upper control arm crossmember and rear end brackets tack welded in place
Installing the rear coilover shocks
Everything was installed according to the directions and this is the lowest it would go.
After talking to Rod & Custom they said to turn the lower shock mount over
This is the ride height now with no weight in the car
Rusty Gillis
Port Richey Fl
Old 11-12-2015, 11:57 AM
GPR's Avatar
GPR GPR is offline
With weight in the car I think the ride height will be about right
Welded the rear valance in place
Welds ground
We wanted to do something different for the exhaust. We cut the exhaust outlets from a 1967 valance but had to make it a little larger to fit our tail pipes
Welds ground
Rusty Gillis
Port Richey Fl
