Old 10-19-2016, 06:44 AM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Originally Posted by MillerBuilt View Post
C6/C7 Hybrid Floater System -
[SIZE="4"]Installs onto GM 10/12 Bolt (except Impala or Truck)[/SIZE] rear-ends,,,,, BOLT-ON!
That's right, you can use your current GM 10/12 Bolt rear-end housing, NO welding & simple installation!
Advantages:
  • Bolts to GM 10/12 Bolt housing end / brake flange (except Impala or Truck)(Big Ford application also available! https://lateral-g.net/forums/showthread.php4?t=49657 )
  • Eliminates the weak/dangerous factory c-clip axles
  • Reduces/eliminates brake “knockback”
  • Eliminates axle deflection
  • Wheel & tire remains intact should an axle failure occur
  • Front or Rear Caliper / E-Brake Cable Positions
  • Utilizes the robust, zero maintenance C6/C7 ZO6 Hub Bearing Unit
  • Utilizes OEM C5/C6/C7 Corvette, and 5th/6th Gen Camaro brake kits
  • Utilizes aftermarket C5/C6/C7 Corvette, and 5th/6TH Gen Camaro brake kits
  • Utilizes your existing BAER / WILWOOD caliper & rotor (some restrictions apply)
  • Super compact design compared to traditional style full floaters
  • All advantages of a traditional style full floater without the maintenance
  • Replacement parts available at local GM dealer or local parts house
  • No modifications required to the hub bearing unit as other kits in the marketplace
Note: this applications will add 1/16″ per side to your existing wheel mount surface (based on an existing 2.810″ axle/brake offset)
Fitment: OEM 10/12 Bolt Rears: 67-81 Camaro, 64-72 Chevelle, 64-74 Nova
GM 10/12 Bolt Bolt-On “Base Kit” (pictured below)
GM 10/12 Bolt Bolt-On “Base Kit” (pictured above)
Base Kit Includes:
• (2) Billet Steel, C-Series, Hybrid Floater Adaptors
• (2) Billet Aluminum Caliper Brackets
• (2) SKF 33 Spline Hub Assemblies
• (1) Install Kit
• (2) Hub Spacers
• (2) Billet Aluminum Hub Cap Seals
________________________________________
STARTING AT - $1698.00
Add Axles - $400.00
• (2) Hy-Tuf Full Float Axles
Add E-Brake items - $325.00
• (2) C5/C6 Corvette Complete E-brake Assemblies
• (2) C5/C6 Corvette Parking/E-brake Cable Brackets
Have interest?
Have questions?
Need more info?
Dealer Inquires Welcome!
Below pics of the assembled "Base Kit".... (attached 10/12 Bolt End is for display purposes only)
Below pics shown with optional C5/C6 E-brake Assembly & E-brake Cable Bracket. These two e-brake items are optional and the system can be run without and added at a later date if desired.... (attached 10/12 Bolt End is for display purposes only)
Few pics below of this 10/12 Bolt Kit in action!
In Stock!
Last edited by MillerBuilt; 11-28-2017 at 07:52 PM. Reason: e-brake price increase
Old 12-27-2016, 10:50 AM
jonathonar89 jonathonar89 is offline
Very interesting kit. I haven't come across this product until joining this forum. I take it, this also changes the bolt pattern to late GM metric pattern?
Old 12-27-2016, 01:08 PM
Yes ....and if you have aftermarket spindles that have c6 hubs you now have a matched set ...
Old 12-27-2016, 07:05 PM
Very cool. This is a nice product to match for the guys running CPP or Speedtech spindles with the corvette front hubs on early GM subframes. DSE and AME cars also use the corvette hub up front as well. With many people chasing down LS engines, corvette brakes and late model wheels, this is an interesting product to see.
Good stuff!
Old 12-28-2016, 05:44 AM
66tintop's Avatar
66tintop 66tintop is offline
Cool Great idea !!!
That's some slick sh!t there, someone's using their brains , thanks for sharing
Old 12-28-2016, 06:40 PM
Thanks guys..
I pretty much have an application for everyone!
GM 10/12 Bolt Kits -
https://millerbuiltusa.com/chevy-1012-bolt-base-kit/
Big Bearing Ford Kits -
https://millerbuiltusa.com/big-ford-base-kit/
Moser 7900/Strange H1143 Kit -
https://millerbuiltusa.com/hybrid-fl...ms/moser-7900/
Universal Weld-On Kit -
https://millerbuiltusa.com/universal-weld-on-base-kit/
And don't forget about axles!
OEM Style -
https://millerbuiltusa.com/solid-axles-oem-style/
Full Float Style -
https://millerbuiltusa.com/solid-axles/
Old 12-28-2016, 11:18 PM
T_Raven's Avatar
T_Raven T_Raven is offline
I just noticed you have 2 axle styles.
For the full floater style, are those black caps with the set screws and o-rings holding the axle and fluid it?
Is there any reason to run one style of axle over the other?
67, 68, 69 & 72 Firebirds, 79 TA, 89 GTA, 01 WS6, 68 Camaro, 68 Mustang, 54 GMC awd turbo, 67 GMC
Old 12-29-2016, 05:32 PM
You are correct T_Raven. The billet aluminum Hub Cap Seal pictured in all of the Hybrid Floater Kits does in fact retain the full float style axle as well as seals any diff fluid from escaping.
Both axles ultimately act/perform the same. Some folks may prefer GM/OEM type design/technology, while others may prefer a more traditional style full floater axle.
The full float style axle is more cost effective so may be the deciding factor for most..
Great question and thanks for asking.
Jay
Old 02-09-2017, 07:55 AM
Sonar Chief's Avatar
Default Great product!
Jay, awesome product! Got the kit put on my housing and then decided to detail the hubs so I took it all apart again ...
Here's some pics of my install with the caliper forward of the axle which places the parking brake access to the rear which would lengthen the cables to enter from behind the axle .... then this idea came to me!!!
Swap the parking brake adjuster/ lever and the parking brake cable bracket from right to left and have the parking brake access in the front now!!!
Any reason this would NOT work? Since I have them apart to detail I'm going to mock it up!
Michael
Old 02-09-2017, 11:16 AM
Cool
Well this idea bugged me all last nite ... so I got up at o dark thirty and got to work swapping the sides and ... it seems to me that it will work! Please chime in if you see something that I don't but it looks like the angle of the dangle on the cable bracket will work!
FYI ... for redneckery ideas on getting the hub bolts torqued to 94 ft/lbs when both pieces rotate, just stand the wheel up and use the bar to stop the rotation! Just a thought ... hope it helps!
Ok now I have to take it back apart and Loctite and torque all the bolts.
Michael
