Old 04-01-2019, 10:27 PM
DBasher's Avatar
DBasher DBasher is offline
Gunner now sits next to:
Thrasher
Red Devil
Jackass
Mayhem
Well played.
Old 04-02-2019, 12:45 AM
fleet's Avatar
fleet fleet is online now
Thrasher
Red Devil
Jackass
Mayhem
Old 04-02-2019, 03:32 AM
Stielow's Avatar
Stielow Stielow is offline
Now where caught up. I’m in the process of attempting to get it running this week.
Stielow Engineering
Old 04-02-2019, 05:43 AM
TorqStorm's Avatar
TorqStorm TorqStorm is offline
Turned out great, nice work!
Torqstorm
[SIGPIC][/SIGPIC]
www.torqstorm.com
Old 04-02-2019, 06:28 AM
Pantera1889 Pantera1889 is offline
Cool truck!
Ron
Old 04-02-2019, 07:53 AM
clill's Avatar
clill clill is offline
The problem is it will be full of dog hair.
Old 04-02-2019, 08:25 AM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Default Old AC with new 5.3?
Mark,
Can you address what was easy and what was difficult if anything?
ie. Old AC with new 5.3L?
Every looks like it just dropped in easily and fell into place!
Great job as always!!!
p.s. when do you want me to ship you my 2nd Gen F-body? LOL
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 04-02-2019, 10:56 AM
Stielow's Avatar
Originally Posted by OLDFLM View Post
Mark,
I used the Holley mid mount accessory drive that gave me a clean a/c mount and power steering pump.
If I would have pitched an aftermarket wiring harness this deal would have been fairly straight forward. Use all the GM stuff made it look cool be a bit more work to sort out the wiring.
Stielow Engineering
Old 04-02-2019, 05:56 PM
Revolutionary Revolutionary is offline
Outstanding build!
Old 04-03-2019, 06:55 AM
Stielow's Avatar
Mark,
The engine, trans and stock exhaust manifolds fit fine. I had to make custom engine mounts to position it where I wanted it. I think Holley sell mounts now. I just made my own because I knew it would fit.
The transmission mount was easy. I used the stock 78 Blazer transmission crossmember and mount and moved it back one set of holes. So far on the engine swap I had to drill two holes for the trans crossmember. The hot side of the exhaust the passenger side was stock and the drivers side needed reworked. I retained all the catalytic converters for cheap mufflers.
The Holley accessory drive fits great and solves the power steering pump issue that LT have.
The stock radiator went in very easy.
So far this has been one of the easiest projects I’ve ever done.
It’s been a lot of fun so far.
Mark
Stielow Engineering
