Old 04-17-2007, 07:59 PM
Steve1968LS2's Avatar
Originally Posted by zbugger
Those look just fine.... For a motor run with no oil. Good god man!!! Is there any way to make sure the oil galley isn't blocked in any way to make sure that doesn't happen again?
Yep, everything has been thouroughly cleaned, inspected, cleaned and redone. The oil pump has been rebuilt, ported and double checked.
The oil pan has been tanked, scrubbed and checked over.
The factory oil pump seemed a little wacked. the valve was sticky. Hard to know for sure at this point. I will send the cam to COMP so they can check it out.
We may never know what happened but we are going on the principle of "replacing everything it could have been"
Hey, it's a learning experience and will make getting the car done that much sweeter. (I tell myself that as part of my therapy.. lol )
Old 04-17-2007, 08:01 PM
Originally Posted by streetfytr68
Needs two turbos
Now that I know how easy it is to pull the engine I'm thinking that a little FI might be in order down the line to "liven things up"
Right now I just need her done for her date with the Super Chevy cameras..
Old 04-18-2007, 08:30 AM
Musclerodz's Avatar
Dad to hear, sounds like a very dry start. Any warranty from GM on a new LS2? Probably was damaged on the intial fire. Too tight tolerances will kill one. Of all the issues I am hearing with GM crate motors I am growing less fond of them.
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 04-18-2007, 08:37 AM
trapin's Avatar
trapin trapin is offline
Wow...I can't believe just a little bit of low oil pressure can chew the hell out of a crankshaft like that. Sorry to hear that, Steve. But that's hotroddin' for ya. Two steps forward, five steps back. I'll be watching my oil system closely on my LS1 as a result of this.
Tony Rapin
The Pigeon Forge Project
A 1968 Pro-Touring LS1 Camaro.........and why not?
Old 04-18-2007, 09:08 AM
Mike
I don't think the warranty applies if you swap heads, cam and intake then dyno flog it.. lol -- sorta hard to blame GM.
We had TONS of oil pressure on the engine dyno. Then again all it takes is one pull where it drops. Engines blow up, it's in there nature. The whole process of an engine working is extremely violent if you think about it, it's nearly amazing that they work as well as they do.
Should have the engine back together today and back in the car tomorrow. In a month it will just be a "funny story" that I can tell when I'm out cruising around the Camaro.
Old 04-18-2007, 09:12 AM
Musclerodz's Avatar
Didn't remember the dyno. Was anything changed or modified on the motor from dyno to car? Like the oil pan where pump depth might have been altered?
Mike
Mike Redpath
facebook page
Old 04-18-2007, 09:16 AM
Mean 69 Mean 69 is offline
Holy moly!!!! That'll get your attention. I'm guessing that you didn't ahve the ability to tank the block out, i.e. boil the heck out of all of the galleys, etc? I'd be checking the break-in oil big time if you didn't have the op' to tank it all out. Run it, change it, run it, change it....
Every car has a story I guess, some more than others.
Steve, please check your pm's.
Mark
Old 04-18-2007, 10:38 AM
Mark
The block was steam cleaned at the shop next door, cleaned some more then steamed again. Every part was cleaned and re-cleaned. We will run some dino oil through it on start up then then drain and refill.
I did name her BAD Penny.. I guess she's earning it. lol
Old 04-18-2007, 10:39 AM
Mike
We added an f-body oil pan, pick-up tube and windage tray. I guess there could have been some sort of contamination. We did clean it good though.
Could of a been a problem that started on the dyno and got worse, hard to say.
Old 04-18-2007, 03:16 PM
novanutcase's Avatar
These look fine.. don't ya think?
OH ****!!!!! WTF??? How did this happen?? Sorry to hear about this! Was there some sort of contamination when you installed the cam? Oil galley blocked?
BTW....thanks so much for the coverage! You and Johnny went WAY beyond what I would have ever expected!(Where do I send the hookers? )
John
