Old 06-15-2007, 08:14 PM
RussMS's Avatar
RussMS RussMS is offline
Sweeeeeeet!
Major congrats man!
Russ
Old 06-16-2007, 08:41 AM
awr68's Avatar
awr68 awr68 is offline
Just watched it on my other machine and the vid worked fine....damn cool Scott!! What's next??
Tony
'68 Camaro
Old 06-16-2007, 07:25 PM
jeff hanson's Avatar
jeff hanson jeff hanson is offline
YOU SUCK! I'm soooooo jealous right now! At least I know what the future holds.
Old 06-16-2007, 08:40 PM
That sounds bad a$$! Can't wait to hear it at full rip.
Jeff Allen
J2 Speed and Custom
Old 06-18-2007, 05:51 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Thanks guys.
Tony, I need to button up some odds and ends like brake lines, subframe connector brackets, etc, and then I can get rolling on getting the subframe painted.
My LS7 69 Camaro
Old 06-18-2007, 08:23 PM
tndude tndude is offline
Originally Posted by kwhizz
Killer sound.............Congrat's.........50 more weeks till your Baby visits Beale St......................
Ken
Is that Beale St. Memphis TN?
Old 06-18-2007, 09:18 PM
JamesJ JamesJ is offline
The start of Power Tour 08
James J.
Old 06-19-2007, 05:42 AM
rich-allen's Avatar
rich-allen rich-allen is offline
Hey Scott, How long did your motor sit prior to firing it up?
Did you spin the oil pump or is that possible with the LS7?
Just curious because mine is coming from the builder in a couple weeks and i want to make sure of the sequence prior to firing it up.
Thanks,
Rich
67 RS/SS
Old 06-19-2007, 05:51 AM
XcYZ's Avatar
It was run late last fall, sometime before Christmas. I filled the dry sump tank and ran the starter a few times for a total of somewhere around 60 seconds to at least prime it some - so it showed oil on the top end when I looked inside the cap on the valve cover. When I fired it up, it had oil pressure instantly. I ran it for about 5 seconds, then shut it off, took it off the jackstands, then rolled it outside and fired it up again, and that's where I took the video that I posted.
My LS7 69 Camaro
Old 06-19-2007, 05:59 PM
pushrod243's Avatar
pushrod243 pushrod243 is offline
Congrats Scott sounds grrrreat
John
