Old 05-08-2009, 09:56 AM
tjbruning tjbruning is offline
Sweet build - love the center dump exhaust tips
Old 05-13-2009, 12:30 AM
CptKlutz's Avatar
CptKlutz CptKlutz is offline
Thanks! Now if I could only free up time to get the rear diffusor done in time too...
We made a grille from a sheet from customcargrilles.com, pattern is called XXL Hexagon and we're going to powdercoat it black. I made a 2D drawing to work from if anyone needs it, but basically you bend over the original plastic piece.
(and yes, the first try came out too narrow courtesy of USPS)
I was worried about heat soak under the hood and also wanted to reduce front lift even more, so Dustin at CPR and Bob from SoCal Paintworks made some inverted louvers in the hood. A real pain as its all double layer under there and any heat makes it warp. Cant press directly into the hood but needed to weld in a separate piece. Came out great after some bending back in shape!
1969 Mustang GT2 363 Turbo - Work In Progress: https://lateral-g.net/forums/show...&highlight=GT2
Other rides: 1969 Mustang GT1
Old 05-13-2009, 11:21 AM
WhitecatD WhitecatD is offline
Nice work!
Did you TIG weld those louvers on? What filler rod did you use?
62 Nova 400 Under Construction
64 Pontiac Catalina
Old 05-14-2009, 07:13 AM
CptKlutz's Avatar
Yeah, Dustin tigged it with a silicate bronze rod. Lower melting point than normal trying to warp it as little as possible. They may try to MIG the rest because tig puts a lot of heat in the metal by nature.
Old 05-14-2009, 08:19 AM
rat_rod_russell's Avatar
rat_rod_russell rat_rod_russell is offline
Have you tried a pulse instead of constant current? I feel the sheet metal I've done warps less when I'm using the tig on a low current pulse setting. and you end up with less grinding too.
-Russell
Old 07-23-2009, 01:00 AM
CptKlutz's Avatar
So, here the latest update on the build. Holidays and other stuff has been in the way but its finally getting color. Finished the hood louvres - what a warping pain! Russell, I don't know how they welded it in the end but there was a good deal of warp to say the least. Got Bob from SoCal Paint to fix it, he knows the tricks.
Also the grille is finished and ready for powdercoat:
I/C and tubing finished:
Also got a little crazy on a last minute detail, a window net. Don't give me a hard time on that, I've just always wanted one since I got to drive a real NASCAR. It's bolted in in the pic, but yes there will be a quick release of course.
Color is 2008 Lotus Exige British Racing Green, a really old school BRG without any metallic at all. Really fits the Mustang IMHO. This is shot b4 the clearcoat. It will get a 1/4" white pinstripe as separation between the green & black, inspired by the George Folmer Trans Am car.
Old 07-24-2009, 06:16 AM
yumyumchoppers yumyumchoppers is offline
Who's VW pan in the background?
Old 07-24-2009, 07:12 AM
Tom.A's Avatar
Tom.A Tom.A is offline
Looks great and awesome build
Tom
Old 07-24-2009, 07:26 AM
Just wondering
WOW, that one's coming along and looks killer I love the turbo piping.
You might play with the White Balance on your camera It kinda looks turquoise and dark blue lol.
-Russell
Old 07-24-2009, 12:53 PM
CptKlutz's Avatar
Thanks!
The car is outside SoCal Paintworks, they always seem to have 1-2 VW's going on.
The British Racing Green has a lot of blue in it but you should play with your monitor settings I think!
