Old 03-18-2012, 10:02 AM
awr68's Avatar
awr68 awr68 is offline
Congrats on the first born! There's nothing like it!
Car looks good too!!
Tony
'68 Camaro
Old 03-18-2012, 12:21 PM
Congratulation's on the new car guy! I like the shirt. Nice progress on the car.
Old 03-20-2012, 08:11 PM
almcbri's Avatar
almcbri almcbri is offline
Default fuel lines!
Thanks Guys! He is a lot of fun.
I worked on the fuel lines tonight and I have came up with a budget fuel line set-up for fuel injection. I purchased some nylon fuel line that is commonly used on GM EFI cars today. If GM uses them, I would think are reliable and have been used on cars for quite awhile now. I spent a total of $102 for 3/8 line, 5/16 line and fittings.
$102 fuel line and fittings
$32 99+ Corvette fuel filter regulator from Rock Auto
$12 3/8 to 3/8 push connect fitting to connect to the fitting to the fuel filter/regulator.
$75 255 Walbro Fuel Pump
$60 94-96 Caprice Tank and sending unit (salvage yard)
$8 Fuel Line rubber clamps from Lowes
I am planning on buying a new sending unit just to be on safe side. They run $120 from rockauto.
Pretty reasonable and hopefully reliable factory style set-up. If anyone has any concerns or has had problems with this set-up let me know.
Old 03-21-2012, 09:49 PM
CarlC CarlC is offline
There's three main concerns with using the plastic lines:
1) The proper installation of the fittings to the line (using the dedicated tool is best.)
2) Routing the lines far away from heat sources.
3) Not inducing a permanent bend by heating the tubing (i.e. the hot water trick.)
There are some connectors out there that are really nice but have not leaked down to the aftermarket yet. The parts used on the new GM cars have an o-ring on the sealing barb and a very good double security locking mechanism.
http:www.vaporworx.com
Old 03-24-2012, 07:51 PM
almcbri's Avatar
Thanks for the reply Carl.
I am almost done with my power steering lines.
I am still waiting on my 11/16x18 fitting for the supply side. The hoses were made at Napa. They are made with 5000 psi hose which is overkill but they will serve just fine.
I used a metric fitting that converted to a 5/8 fitting.
They ran me right at $90
M16x1.5 fitting that converts to 5/8. This was used on the ls1 pump side.
11/16x18 supply: 27" of hose + fittings and 90 degree 3/8 steel tube.
5/8x18 return: 17" in length of hose + fittings to connect to ls1 barb on pump.
Old 05-12-2012, 06:47 AM
almcbri's Avatar
My 68 was dropped off yesterday for paint! I can't wait to see it painted.
10 year project and I am finally getting on the down hill side. Pictures will be coming soon!
Old 05-12-2012, 07:26 AM
cencalc6 cencalc6 is offline
congrats!
Old 09-16-2012, 04:10 PM
almcbri's Avatar
The car has been in the paint shop all summer and in the last month they have started working on it quite a bit. I think I might see it back in a month or less.
They ended up blowing the front sheetmetal back apart and re-working for a better fit. I thought everything was lining up pretty well but I am really excited about how much better everything is fitting.
I have been organizing the garage a little bit and getting all my parts in order for re-assembly. I even got one seat recovered.
Old 09-16-2012, 05:45 PM
It looks good, nice to see the light at the and of the tunnel!
Old 09-16-2012, 06:00 PM
coolwelder62's Avatar
I'm really liking the OEM style fuel line's.cool project.
